Audi a3 2.0 tdi BKD Ignition Issue: Error 18009 & Terminal 30 Start Failures
baton.e30 16029 7
  • #1 16545743
    baton.e30
    Help: 50
    Rate: 380
    Hello, as in the title, error 18009, the car does not start, when the ignition is turned on, the incandescent light turns on and the power steering starts to work even though the engine is not working, after about five seconds the fans are turned on, the fuel pump in the tank cannot be heard. After turning the ignition off and on several times, it is surprising, the chek engine light appears, the pump can be heard and the car starts. Then it goes out and it's the same again. I will add that the fuses and relays are checked, the masses are checked. There used to be a problem with the unit injection, but it does not crash this error anymore, I do not want to suggest anything, but it's piezo siemens and if one is damaged, the car will not start
  • #2 16546230
    buncza
    Help: 10
    Rate: 94
    You replaced the J317 relay - because it points to it.
  • #3 16547431
    baton.e30
    Help: 50
    Rate: 380
    Relay 458? Yes, I changed the main ignition
    Relay 458? I changed this, the main ignition and 433 I changed places
  • #4 16547871
    panstalin2
    Help: 30
    Rate: 216
    The contacts of the relays are functional - how do you bring your nose closer and smell it?
  • #5 16548281
    baton.e30
    Help: 50
    Rate: 380
    I wrote, all fuses and relays were checked, the cassette next to the battery was also removed, the contacts were OK
    panstalin2
    Help: 30
    Rate: 216
    In place of J317, after turning the ignition, there is power on the coil of this relay? - The connected 21 W light bulb is normal?
    There is power on the current contact to ground?
    On the second contact, the current draws the current - the connected H4 bulb from the + battery to the contact should shine half of its brightness.
  • #7 21883758
    lokipakas1918
    Hello, have you fixed this somehow? I have the same problem :/
  • Engine control unit replacement fixed start failure
    #8 21889485
    tomku77
    Rate: 48
    I had the same problem and it turned out that the engine control unit was to blame. I gave the car to a friend who does this sort of thing, he replaced the controller, copied everything from the old one and the car runs just fine. He said it was a common problem with these cars. The controller was nice and no water got into it. he charged 600PLN for the whole thing. I don't know if this is a lot or a little, but I wouldn't have been able to do it myself anyway ;)
Audi A3 2.0 TDI BKD with fault 18009 has intermittent no-start behavior: after ignition on, glow plug lamp and power steering activate, then fans start after a few seconds, while the in-tank fuel pump is silent. After several ignition cycles the check engine light appears, the pump primes, and the engine starts, but the fault returns. Fuses, relays, grounds, and the battery-side relay box were checked; J317/main ignition relay 458 and relay 433 were swapped/replaced without resolving the issue. One suggestion was to verify power at the J317 relay coil and load contacts with test bulbs. In a later reply, the same symptom was traced to a faulty engine control unit, which was replaced and cloned from the original ECU, restoring normal operation.
