Audi A4 1.9TDI AJM Error 17965 - Recurring Turbo Boost Control Issue
tomekb 85029 17
Why does my Audi A4 1.9 TDI AJM keep showing fault 17965 (turbocharging regulation limit exceeded) after the turbo vanes were cleaned, and where should I look for the cause?
Check the turbo’s variable-geometry mechanism and the N75 control path first; this fault points more to overboost from sticking parts than to a simple vacuum leak. [#7814403] The most likely causes mentioned are the variable geometry hanging again in the maximum position, the actuator rod/bar sticking in its guide, or a clogged atmospheric vent channel in N75 / the hose from N75 to the air filter. [#7814403] Use VAG Basic Settings 011 to see whether the rod moves through the full range, and if needed test the actuator with a hand vacuum/pressure pump to confirm smooth movement and diaphragm tightness. [#7813281][#7815382][#7812895] After cleaning or repair, clear fault 17965 from the ECU and retest, because one similar case was cured simply by deleting the stored error. [#8015498]
  • #1 7811851
    tomekb
    Help: 54
    Rate: 210
    the patient is A4 1.9TDI AJM
    the car noticeably "silted up", Vag showed error 17965 "turbocharging regulation limit exceeded"
    The steering wheels were cleaned two weeks ago, they were completely dirty
    After cleaning, the car came to life noticeably
    but now history has repeated itself, where to look for the reason????
    I`m waiting for information
    Regards
    T
  • #2 7812057
  • #3 7812087
    tomekb
    Help: 54
    Rate: 210
    ok, thank you, I`ll start checking tomorrow
    N75 is new, i.e. 2 months old, but I will test the actuators
  • #4 7812113
  • #5 7812895
  • #6 7813281
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    011 -->BS and see if it moves the bar throughout the entire range
  • #7 7814403
    Sztomel
    Help: 284
    Rate: 1237
    With the error described, there is no point in using a vacuum pump or checking the vacuum hoses and coils for tightness,
    After all, the turbo overloads, so what are we talking about leaks? In this case there are only three possibilities:
    - variable geometry hangs again in the max position. top-ups,
    - the barbell gets stuck inside the vacuum tube,
    - clogged ATMO channel in N75 or the hose leading from it to the air filter.
    Stop looking for any leaks - this is not the way to solve the problem, if you notice that the variable geometry is jamming, file a complaint with the contractor - unless you cleaned it yourself ;)
  • #8 7814598
  • #9 7814643
    Sztomel
    Help: 284
    Rate: 1237
    Motronic wrote:
    I got a reprieve from you. What barbell is inside the coil?
    However, I was amused by the fact that the bleeder in the VNT does not work, my friend, and as for the barbell, it does not end or start at the pear itself, but is connected to the piston inside the pear, so I don`t know what made you laugh in my statement. ;)
  • #10 7814673
  • #11 7814705
    autoas
    Help: 571
    Rate: 3922
    Yep, I also saw corroded and cracked springs in the "pear" which resulted in "overloading"
  • #12 7814715
    Sztomel
    Help: 284
    Rate: 1237
    Maybe you haven`t had such a case, but I did, the barbell is corroded inside and jams in the plastic guide sleeve and the spring is unable to rebound it, progressive corrosion is caused by water that gets inside through the hole that equalizes the pressure inside the bar from the barbell side, the guide sleeve is visible on the barbell in the photo below, so jamming the barbell inside the barbell is quite normal and not an extreme phenomenon at all:
  • #13 7814731
  • #14 7815170
  • #15 7815382
    Sztomel
    Help: 284
    Rate: 1237
    Yes, it can be used to check the operation of the variable geometry, but you can also perform a Vag test in 011 Basic Settings or check the stroke range and possible resistances with your hand, and in the specific case described, we can only push the bar with pressure because we won`t be able to do anything with the vacuum since the bar is pulled in as far as it will go and rests against the stop on the turbocharger body.
  • #16 7815848
  • #17 8015498
    cineklu
    Rate: 8
    Tomekb, I had a similar problem, the turbo had to be cleaned, after cleaning the car came back to life, but sometimes it didn`t drive properly. It turned out that they did not delete the error from my computer (error no. 17965). A short play with the vag and the pain is over. :D
The discussion revolves around a recurring turbo boost control issue in an Audi A4 1.9TDI AJM, indicated by error code 17965 ("turbocharging regulation limit exceeded"). The user reports that after cleaning the steering wheels, the car initially improved but the problem returned. Responses suggest checking various components, including the N75 valve, vacuum hoses, and the variable geometry of the turbocharger. Several users emphasize the importance of inspecting for mechanical issues such as stuck components and clogged channels rather than focusing solely on vacuum leaks. Recommendations include using a manual vacuum pump for diagnostics and ensuring that any previous errors are cleared from the vehicle's computer system.
