Challenges Transferring YouTube from Windows 7 64bit Computer to TV: No Cast Device Detected
wirus1 7965 4
  • #1 16567895
    wirus1
    Level 19  
    Rate: 11
    The problem is the subject. Oddly enough, you can transfer YouTube to TV from your tablet or phone. I will add that the TV is normally seen on the network. As I even manually want to send, I have the message no cast device detected.
    On another laptop is ok, tablets and phones send the image to this TV. All devices are connected to one router.
    It doesn't transfer from just one computer: Windows 7 64bit (freshly installed)
    Please help
  • #2 16567915
    DriverMSG
    Help: 3984
    Rate: 4891
    The system itself does not send an image on the network. What program do you do? A network card adapted for this purpose?
  • #3 16571860
    wirus1
    Level 19  
    Rate: 11
    Via google cast simply in google chrome when you enter on youtube it has always been an option to send to another screen such icon Challenges Transferring YouTube from Windows 7 64bit Computer to TV: No Cast Device Detected
    It is currently unavailable on this one computer after reinstalling windows, on others it works.
    Added after 4 [hours] 43 [minutes]:
    No one can really solve this problem?
  • #4 16571974
    DriverMSG
    Help: 3984
    Rate: 4891
    wirus1 wrote:
    It is currently unavailable on this one computer after reinstalling windows on other works.
    If you put a comma, you could better understand what you are writing.
    You don't answer the questions, and that's quite important, because we don't even know if you are connecting through a router (what?), Via LAN cable or WIFI, or is the network properly configured?
  • #5 16573697
    wirus1
    Level 19  
    Rate: 11
    I connect through a router to which a cable antenna (unitymedia) cable is connected. All devices are connected through this router. The laptop does not stream youtube other devices like this. The network card doesn't make any difference in this case. Another much older laptop works ok and streams youtube on smart tv.
