12V Electric Motor for Car Compressor Capable of 10 Atmospheres & Long-Lasting Performance
fred77 6666 15
Can I use a 12 V electric motor to drive a car compressor that reaches 10 atmospheres and can run for long periods without overheating?
Not realistically: a compressor that can do 10 bar for long periods needs far more power than a normal 12 V car system can supply [#16577878][#16577903] One example cited a 10-bar bus compressor driven by a 4 kW, 400 V AC motor, which would be about 335 A at 12 V [#16577878] The most reliable car solution is to drive a traditional compressor directly from the engine crankshaft pulley, or use the A/C compressor clutch if that fits the application [#16577903] If you only need air for tires, a horn, or short bursts, use a quality 12 V off-road wheel compressor in the 300–500 W range, ideally with a tank, safety valve, pressure switch, and relay [#16581563] Another option mentioned is a factory VW/Audi 12 V 10-bar compressor, which is reusable and intended for wheel inflation [#16580907]
  • #1 16577837
    fred77
    Rate: 23
    I do not know if this is a good department, but the question may be a bit unusual, so I am asking here.
    I need a compressor in my car. It is supposed to pump air up to 10 atmospheres. And the easiest way would be if it was powered by a 12V electric motor.
    Traditional, reciprocating compressor, e.g. from a farm tractor or a truck, driven by a V-belt through pulleys with a properly selected ratio.
    Are there any 12V electric motors available that would cope with this task? The point is that such an engine can pump air without problems, it can work for a longer time and that it does not overheat.
  • #2 16577875
  • #3 16577878
    sanfran
    Help: 960
    Rate: 2999
    By coincidence, I know that the compressor with a pressure of 10 bar in hydrogen-powered buses is driven by a 4kW motor at 400V AC.
    http://www.vanhool.be/Home%20FR/transport%20p...0a%20combustible/Resources/folderFuelCell.pdf
    Rather, I do not think that it is possible to choose a 12V motor, it comes out 335A of the rated current. Of course it all depends on the pressure output, but I don't think a fuel cell bus needs less compressed air than a traditional vehicle.
  • #4 16577903
  • #5 16577954
    Megawe
    Help: 246
    Rate: 1436
    The easiest way is to convert the starter to the bearings.
  • #8 16578175
    Staszek49
    Help: 228
    Rate: 1140
    It will be difficult for you to use such a device in a car (probably a passenger car) due to the high demand for electricity. If you have a bigger car and a more powerful engine, you can use it to drive a traditional compressor. In this case, select only the place of its installation and install an additional pulley. If it is to be, for example, a (special) demonstration vehicle, which will "sway and jump" with the aid of pneumatics, then I suggest installing a larger air tank, filling it with a compressor first.
  • #9 16578712
  • #11 16580815
    fred77
    Rate: 23
    The air will be used only for the pneumatic horn, for inflating the wheels and for blowing something with compressed air.
  • #12 16580841
    WędkarzStoLica
    Help: 146
    Rate: 300
    Then you have to look for a smaller compressor :)
    Then the 12V bicycle motor - they are cheap, strong and adapted to continuous operation.
  • #13 16580882
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6422
    A Chinese compressor is enough to inflate the tire and a small tank too.
  • #14 16580907
  • #15 16580945
    WędkarzStoLica
    Help: 146
    Rate: 300
    Could use something more efficient and not with a plastic plunger :)
  • #16 16581563
    teskot
    Rest in Peace
    Help: 420
    Rate: 957
    I propose a wheel compressor for off-road cars plus a cylinder, a safety valve, a pressure switch and a relay. Such a compressor has a power of 300-500W, quite high efficiency and decent build quality. I know because I use it myself. It costs about PLN 200. An old fire extinguisher can be used as a reservoir. For this, of course, a solenoid valve to start the horn and the appropriate pneumatic fittings for connecting the peripherals.
✨ The discussion revolves around the feasibility of using a 12V electric motor to power a car compressor capable of reaching 10 atmospheres (10 bar) of pressure. Various responses highlight the challenges associated with high current demands, suggesting that traditional compressors driven by a vehicle's crankshaft may be more efficient. Some users recommend specific types of compressors, such as those used in power steering systems or off-road vehicles, and mention the possibility of using a smaller 12V bicycle motor for continuous operation. Additionally, brands like VW and Audi are noted for having factory-equipped compressors that meet the specified requirements. The conversation also touches on the use of air tanks and pneumatic systems for various applications, including inflating tires and powering pneumatic horns.
