Wiwa HD100, HD-100 - green LED is blinking, black screen is not responding
13722 2
  • #1 16582490
  • #2 16582521
    qs300
    Help: 242
    Rate: 362
    I also had a similar problem with the Cabletech decoder, I used it for about 2 years, after which he stayed in the closet for half a year. After half a year I had to use the decoder again, but it didn't turn on, only the LED was on.
    After removing the housing, it turned out that one of the capacitors had swollen, I replaced it and the decoder works.
    So let's dismantle the set-top boxes and check if everything is OK with electronics, because a slightly swollen capacitor may cause a hardware failure.
  • #3 16583646
