- Xiaomi Redmi 9 Pro Not Turning On: Logo Flashes Every 3-4 Seconds While Charging
Daszu9 37578 5
  • #1 19285032
    Daszu9
    Whats up, as in the topic, the phone does not start after connecting to charging every 3-4 seconds, only the logo turns on as when turning on the phone and immediately turns off. I will add that the phone had 13% and was connected for the night. The phone is new because it was bought a month ago. I am asking for a quick answer.
  • Uncharged battery likely causing boot loop
    #2 19285179
  • #3 19285201
    c-y-r-u-s
    Help: 12
    Rate: 35
    Change the batteries, 90% is hers.
  • Suggests charger, cable, socket, or charging circuit fault
    #4 19285399
  • #5 19285582
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    If, after charging us for a long time, the other charger does not get up, you will not do anything without opening the phone. Either a complaint or a service.
  • #6 19286085
    Daszu9
    OK, thanks, but it probably won't be without service. Subject to be closed.
