Connecting a 2-Wire Lamp to a 4-Wire Cable: Utility Room Lighting with Black, Blue, Brown Phases
LucaO 23874 9
Can I connect a simple two-wire lamp in this room by wiring it to one phase conductor and the yellow-green wire?
No, the lamp should be connected to a phase and neutral conductor, and the protective conductor is used only if the lamp’s design requires it [#16602280] The thread also warns that you should not assume the wire colors are correct, because the supposed phase/neutral labeling in the box may be wrong [#16602222] If this is a junction-box installation, the switched phase should go to the lamp, together with neutral and protective conductor where applicable [#16602222] Because the installation is unclear and existing protections are unknown, several replies say the box should be checked on-site by a qualified electrician before connecting the lamp [#16602222][#16602257]
  • #1 16602147
    LucaO
    Rate: 73
    I have a utility room in which there is a can with wires, exactly like this:
    Black - phase
    Blue - phase
    Brown - phase
    Yellow green - zero
    I would like to connect the simplest lamp to have lighting in the room, I have a lamp with two wires, is it enough if I connect one phase to it and a yellow - green wire?
  • #2 16602179
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Black - phase
    Blue - phase
    Brown - phase
    Yellow green - zero
    Exactly.
    Moderated By retrofood:
    Any new installation? So I appreciate the hurried training of new staff with the warning. point 3.1.11 of the regulations.
  • #3 16602180
    kokapetyl
    Help: 1787
    Rate: 2101
    LucaO wrote:
    Black - phase
    Blue - phase
    Brown - phase
    It's very weird. How did you say that?
    No no. receiver (your lamp must be connected to a phase and neutral, additionally use a PE wire (depending on the design of the lamp).
    daro31ie wrote:
    Exactly.
    What do you mean ? Because from what you see you write nonsense. :cry:
  • #4 16602191
    daro31ie
    Help: 366
    Rate: 650
    If the guy checked that he had black, blue and brown phases, where is the problem?
  • #5 16602197
    kokapetyl
    Help: 1787
    Rate: 2101
    daro31ie wrote:
    so where is the problem?
    In the fact that you do not know what you are writing, and the author is also not very sure. :cry:
  • #6 16602204
    LucaO
    Rate: 73
    So how ?
    From the lamp switch I release two cables, one phase (L) and one yellow-green (Protective), into the box, I also release two cables from the lamp with the same markings, and what should the connection in the box look like now?
    LucaO wrote:
    So how ?
    I will add that there is no Neutral cable in the installation, there are 4 wires
    3 x phase (L)
    1 x Protective (Pe)
  • #7 16602208
    daro31ie
    Help: 366
    Rate: 650
    LucaO wrote:
    So how ?
    Buddy from the can you give a brown phase wire to the switch, then from it to the lamp.
    You connect yellow-green directly with the blue lamp.
  • #8 16602209
    rafcio_21
    Help: 137
    Rate: 295
    Since the author has 3 phases in a four-wire cable, he must connect as he wrote in the past, as they did when there were no 5-wire cable, the blue one was for the phase, and the yellow and green one was PEN, i.e. PE and neutral.
    kokapetyl
    Help: 1787
    Rate: 2101
    Buddy, you should call an electrician because you are completely unaware.
    If this is a junction box installation, then.
    The phase conductor reaches the connector, it should go to the lamp after connecting it through the box.
    The lamp should be connected (in the box) to this switched phase, to the neutral conductor and to the protective conductor (all in the above box).
    Colleagues, how do you know that this blue is actually a "phase", maybe it's just the invention of the author?
  • #10 16602257
    retrofood
    Help: 1140
    Rate: 4794
    Black - phase
    Blue - phase
    Brown - phase
    Yellow green - zero
    Want to not always be able to, and reproducing the mistakes made so far is not the best way to get out of the situation. The installation must be seen by a good electrician and he will decide if, where and how this lamp can be connected in this situation. For now, nobody has stammered about existing protections, circuits, so nothing is known here. I close, the topic cannot be solved remotely.
✨ The discussion revolves around connecting a 2-wire lamp to a 4-wire cable in a utility room setup, where the wires are identified as black (phase), blue (phase), brown (phase), and yellow-green (neutral). The initial query seeks confirmation on whether connecting one phase wire and the yellow-green wire is sufficient for the lamp. Responses highlight the necessity of connecting the lamp to a phase and neutral, emphasizing the importance of proper wiring practices. Some participants express confusion over the identification of the blue wire as a phase and recommend consulting a qualified electrician for safe installation, given the potential risks involved in electrical work.
