Appropriate Charging Voltage for a 3.6V Ni-Cd Battery Pack
Qwerti12 12831 19
How should I charge a 3.6V Ni-Cd battery pack and what end voltage should I use?
Charge the Ni-Cd pack with a constant-current source, not a fixed voltage; for a 3-cell pack, do not let the final voltage exceed about 1.4 V per cell, or 4.2 V total [#16607329][#16608687] A simple safe method is C/10 charging for about 14–16 hours, where the charge current is battery capacity divided by 10, for example 600 mAh → 60 mA [#16608687][#16608620] If you use fast charging, stop on -dV/dt and/or +dT/dt rather than relying on voltage alone [#16608427][#16610113] One reply recommends a dedicated charger IC such as MAX712, though it was also noted that this is more suitable for fast charging and may be less beginner-friendly than C/10 [#16607329][#16608620]
  • #1 16607323
    Qwerti12
    What voltage should the 3.6V Ni-Cd battery pack charge?
  • #2 16607329
    Freddy
    Help: 1394
    Rate: 2821
    In such a way that the final voltage does not exceed 1.4V per piece, i.e. max 3 * 1.4 = 4.2V.
    You should also ensure that the maximum charging current of 1C is not exceeded.
    However, it's best to build a simple charger on the system, e.g. MAX712.
  • #4 16608361
    kwazar
    Help: 150
    Rate: 121
    Ni-Cd batteries are not charged with voltage, but with electricity. You need a power source.
    The voltage that will be set on them is only the result of charging with electricity. Charges a specific current at a specified time.
  • #5 16608427
  • #6 16608444
    retrofood
    Help: 1140
    Rate: 4800
    Will it tell a lot to the questioner?
  • #7 16608620
    kwazar
    Help: 150
    Rate: 121
    And this will say more?
    banda.amatorów wrote:
    -dV / dt and / or + dT / dt.
    I have written clearly that a power source is needed. If he doesn't know what it is, let him read. I will not explain to anyone that it charges with stabilized voltage, because it is not done that way.
    You need to put in a little effort to learn something.
    If he reads a bit and asks specifically, I will present him with a diagram.
    Added after 4 [minutes]:
    Freddy, with all due respect, but this is a charger for fast charging of batteries adapted for this. I would not recommend such a charger to a beginner, but rather simple and safe with a C / 10 charging current.
  • #8 16608665
    retrofood
    Help: 1140
    Rate: 4800
    Just. You even pay attention to whom you tell?
  • #9 16608687
    kwazar
    Help: 150
    Rate: 121
    Let's start again ...
    Ni-Cd batteries are charged with stabilized current. That is, a power supply that gives a constant current regardless of the voltage on the batteries. This is called a current source.
    You can make such a source from literally several elements, but you need to know what capacity batteries have. The most commonly recommended standard charging current is around 14-16 hours. is current with the value of C / 10. This means that the battery capacity is divided by 10 and we get the charging current.
    E.g. with 600 mAh battery capacity, the charging current is 60 mA.
    Qwerti12, if you still don't understand something, ask.
  • #10 16608842
    Freddy
    Help: 1394
    Rate: 2821
    Currently manufactured batteries can easily withstand C / 4 current from this charger. Why am I writing like this because I think it is a freshly bought package.
    Otherwise, the user would have registered on the forum earlier than 25.07 :)
    PS. I was very amused by the report on my post # 2 - the content of the report: "Nonsense".
    The user who did this is not brave enough to admit and justify his decision.
    Probably the only word he knows. Please prove to me what is bullshit, or point out my blunder, I publicly bark it back.
  • #11 16609054
    kwazar
    Help: 150
    Rate: 121
    I hope it's not recycled ...
    For now, we have to wait for more data from the person concerned.
  • #12 16609118
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    In principle, when charging with c / 10, only time counting remains, because "dV" may not work.
  • #13 16609180
    kwazar
    Help: 150
    Rate: 121
    It certainly won't work. The ?U detection is for fast charging.
  • #14 16610113
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4259
    With fast charging, the battery heats up strongly and then its SEM decreases - this is what the "minus delta V" method detects. At slow no, but charging with current limitation (stabilization is not needed) to 1.4V / cell gives a sensible result.
  • Ni-Cd charging to 1.4 V per cell with current limit
    #15 16610220
  • Use a transistor sensor for battery temperature compensation
    #16 16611151
    _jta_
    Help: 3212
    Rate: 4259
    I took measurements of the NiCd AA battery voltage at changing temperatures - from what I remember, a temperature increase of 1 ° C caused a voltage drop of 0.2mV. You mean a temperature increase of 35 ÷ 40 ° C? I don't think so down 35 ÷ 40 ° C at 25 ° C ambient temperature? The first means a voltage drop of 7 ÷ 8mV, the second by 2 ÷ 3mV.
    Maybe the easiest way will be to place a temperature sensor (even a transistor) next to the battery - the base-emitter voltage of the silicon transistor decreases by almost 2mV with a temperature increase of 1 ° C - 10 times more than the battery voltage, so detection of this is much easier, and changing the charge is not causes sensor voltage changes ...
  • #17 16611407
    kwazar
    Help: 150
    Rate: 121
    As a side note, I wonder why many people write the interrupt charging method as -?V / ?t
    The voltage symbol is "U" and not "V".
    If you write -?V, you would like to write -?V / ?s, meaning volts and seconds. But symbols of size are written, not units.
    Interesting issue, but on a different topic. I will delete answers here. [Retrofood]
    OKAY.
  • #18 16625774
    Qwerti12
    Okay, I will deal with these NiCd links.
    But if someone could, I would ask for some pattern
    For Aroma 3-FM-4.5 gel battery (6V 4.5AH)
  • #19 16644986
    _jta_
    Help: 3212
    Rate: 4259
    Well, you have written on this battery. There are two basic charging systems: up to a certain voltage, and then disconnect the charger (cycle use), or maintain a certain voltage without a time limit (standby use). And both of them you will find schemes on the forum.
  • #20 16651156
    Qwerti12
    OK thank you
The appropriate charging voltage for a 3.6V Ni-Cd battery pack should not exceed 1.4V per cell, totaling a maximum of 4.2V for a three-cell pack. Charging should be done using a constant current source, typically at a rate of C/10, which means the charging current is one-tenth of the battery's capacity. For example, a 600 mAh battery would be charged at 60 mA. It is important to monitor the charging process, as Ni-Cd batteries do not charge based solely on voltage but rather on the current supplied. The discussion also highlights the importance of temperature monitoring during charging, as increased temperatures can affect battery performance. Various charging methods, including cycle use and standby use, are mentioned, along with the recommendation to use simple and safe chargers for beginners.
