Using NiCd Charger (YX-3515A6) for 4.8V NiMH Batteries: Compatibility and Potential Damage
kapitanwasyl 9510 19
Can I use a 4.8 V Ni-Cd charger to charge higher-capacity NiMH battery packs, and will it damage the cells?
No—this charger should not be treated as a proper charger for 4.8 V NiMH packs, because a simple Ni-Cd charger usually does not detect NiMH end-of-charge, so the cells can be overcharged if left on it [#16256274][#16258661] One reply also says this unit looks more like a simple power supply with current limiting, not a real smart charger [#16258177] For a 4-cell pack, 4.8 V is only the nominal voltage; charging needs about 6 V stabilized, and a 5 V source may never fully charge the pack [#16261149] If you want to use NiMH cells, use a proper NiMH charger or build a dedicated charger such as one based on MAX712 [#16262356]
  • #1 16255836
    kapitanwasyl
    Rate: 18
    Hello, I have a battery charger Nothing: D package 4.8V 400 Mah
    Data on the charger:
    Model yx-3515A6
    Output DC 4.8V 150mA
    Do you want to buy batteries with a larger capacity but NiMh , the charger will be suitable for charging this type of battery, will the cells be damaged?
    I ask because nowhere is it written that the charger is for such and no other links.
    HD-VIDEO
    Help: 1265
    Rate: 1885
    A simple Ni-Cd charger will not detect the end of Ni-MH charging.
    Ni-MH have a much smaller, reduced voltage on them after charging; detection by method - Delta V
  • #3 16257083
    kwazar
    Help: 150
    Rate: 121
    I'm afraid this charger doesn't have a Delta U charging system.
    If so, it is equally well suited for charging NI-MH.
    Maybe some photo of the nameplate?
  • Battery voltage rebounds but packs cannot deliver current
    #4 16257808
    kapitanwasyl
    Rate: 18
    Adds a photo
    There is another problem because I do not know whether the charger has fallen or the battery.
    The voltage on the battery is connected to the device very quickly and gives signs of discharge, however, when measuring the voltage it indicates about 4V.
    Charging does not start when connected to a charger.
    I tried to discharge the battery to about 2V and still the charger does not light the charging diode.
    After connecting to the receiver, the battery loses voltage, but after disconnection it reappears after a while.
    It looks like there is voltage but no current?
    I will explain that the battery pack comes from the son's tank set and the poor cannot drive because the tanks stop after a while, they have not been used for about a year. The first charging after a break was normal, now the chargers are not charging. (There are two and the signs are identical)
    I was thinking about buying new batteries with more capacity.
  • #5 16258177
    kwazar
    Help: 150
    Rate: 121
    It looks like you will need to buy new ones.
    These probably have lost their capacity, voltage increases quickly during charging, and decreases quickly during operation. The classic case ...
    The charger looks like a regular power supply with only a current limitation.
  • #6 16258638
    kapitanwasyl
    Rate: 18
    So NiMh or NiCd to buy?
    Of course, the charger will charge the battery with twice the capacity twice as long.
  • #7 16258661
    Wawrzyniec
    Help: 392
    Rate: 1075
    This charger is not suitable for charging NiMh batteries.
  • #8 16258692
    HD-VIDEO
    Help: 1265
    Rate: 1885
    Because in general it is a charger / power supply / for charging batteries in the device.
    Here, to keep working, you need to buy NiCd batteries.
    They can be bought in the industrial version - with soldering plates
  • #9 16260162
    kapitanwasyl
    Rate: 18
    Today I measured the chargers, give 0.01 V electricity
    I connected the battery for a short time to the universal charger for charging the batteries / sticks - the charger started charging ...
    So both chargers from the toy set have given up the ghost.
    I am currently charging the batteries with the phone charger.
    As the charger has 5 V 350 mA, I connected the batteries in parallel, I do not know if it is correct. When connecting in series, the voltage dropped during charging.
    I will control the battery temperature.
    After about 1.5 hours of charging, the temperature of the cells is unlikely to indicate a rise.
    After test connection to the toy, everything indicates battery charging. The vehicle does not show the battery being used too quickly.
    I wonder if the charger will limit the charging itself, or if you need to watch the charging time.
    In previous chargers, you had to charge the battery for about 3-4 hours
  • #10 16261149
    Wawrzyniec
    Help: 392
    Rate: 1075
    If this charger has a 5V output voltage (stabilized) like typical USB phone chargers, these batteries will never be fully charged, because they need a charger that will give 6V (stabilized voltage), because this is the final charging voltage a package of 4 NiCd batteries (4.8V is the nominal voltage, not the final charging. Analogously, the car battery is called 12 volt, and the car's charging voltage is 14-14,4V). From phone chargers the best charger from the old Nokia would be the best, the one with a thicker plug, it is able to charge this package, but you need to watch the time. The 6V stabilized power supply will also fully charge these batteries and you would not have to watch the charging time.
  • #11 16261211
    HD-VIDEO
    Help: 1265
    Rate: 1885
    The phone charger (no matter if USB or old phones) is just a power supply and is not suitable for charging batteries without an external charging controller.
    Here, this power supply charger from the description indicates charging and can act as a current source and the charge indication is a measurement of battery voltage and nothing more.
    If it is possible, you have to undress it and show what is inside.
  • #12 16261304
    kapitanwasyl
    Rate: 18
    Just if the chargers were dismountable .....
    The batteries were charged to 5.7V
    This afternoon we will drive around the vehicles, then I will write how long it lasted.
  • #13 16262356
    Freddy
    Help: 1394
    Rate: 2821
    kapitanwasyl wrote:
    If you want to buy rechargeable batteries with higher capacity but NiMh,
    It's best to build a solid charger from scratch, e.g. on the immortal MAX712.
  • #14 16262446
    Wawrzyniec
    Help: 392
    Rate: 1075
    Nonsense. See how the chargers for even cheap screwdrivers are built. And the charger for charging the batteries? Are you saying that there must be a charge controller in each? It can't be done otherwise? Strange fashion has now come. Controllers, processors, arduino are pushed to everything, whether it is necessary or not. Soon, you can't drain the water in the toilet. And what will be? Big stench, because no one can do without fancy electronics, and hardly anyone will know simple solutions.
  • #15 16262971
    kwazar
    Help: 150
    Rate: 121
    Although you don't actually need any processors for the alkaline batteries mentioned here, you need a regular power source. After all, these batteries are charged with "electricity".
    You can also use the very good U2400B scalac. I made very nice chargers on it. It is a system that controls, discharges and charges Ni-Cd, Ni-MH batteries automatically.
  • #16 16263221
    kapitanwasyl
    Rate: 18
    / Wawrzyniec /
    This charger is old, just with a large plug, the tip is not for usb. It has a tiny mass / plus pin.
    Unfortunately, one battery holds electricity, the other does not.
    The easiest and cheapest way is to put baskets for AA batteries for toys. Since I have several of them and a decent charger, it will probably be the best solution.
    Purchase of 2 chargers around PLN 40, new batteries around PLN 70 - not worth it.
    A set of tanks cost about PLN 180.
    Wawrzyniec
    Help: 392
    Rate: 1075
    And this is probably the best solution - the cheapest (because without financial), and the tank will travel longer because AA batteries have a little more capacity than the poor 400mAh.
  • #18 16263436
    kapitanwasyl
    Rate: 18
    Another question:
    Can I put batteries of different capacities in one basket?
    (2 x 1300 Ma, 2 x 700 mA)
    kwazar
    Help: 150
    Rate: 121
    Unfortunately, you can't combine batteries like this.
    Batteries working in series should be of the same capacity and preferably of the same manufacturer.
  • #20 16263695
    kapitanwasyl
    Rate: 18
    Thanks to everyone for the advice.
The discussion revolves around the compatibility of the YX-3515A6 NiCd charger with 4.8V NiMH batteries. Users express concerns that the charger lacks a Delta V detection system, which is essential for safely charging NiMH batteries. It is noted that the charger may not adequately charge NiMH batteries, potentially leading to damage. Users suggest that the charger functions more like a power supply without proper charging control. Recommendations include purchasing NiCd batteries or a more suitable charger, as well as considerations for using AA battery holders with higher capacity batteries. The importance of using batteries of the same capacity in series is also highlighted.
