Flashing LED Signal Lamp 838: Enhance Brightness with 230V LED Bulbs, Panels & Strips
zyznos321 6216 10
How can I make a 230V flashing gate signal lamp brighter or adapt it to drive other LED bulbs/strips?
You cannot simply swap in more powerful LEDs or a 230V bulb, because this lamp uses a low-current transformerless supply with the output limited to about 5–6 V and by the series capacitor, so the original LED strips are already current-limited [#16615300][#16615955] The brightness is set by the 181-marked resistors, so you could reduce their value to raise LED current, but that will shorten lamp life [#16614511] For a real upgrade, the forum suggests redesigning the control stage for a triac and using a separate 220/230 V lamp, or replacing the whole middle of the lamp assembly [#16615955] Simply connecting other strips or bulbs to the existing LED output is risky because the internal LED wiring is series-parallel and the current capability is too low [#16615278][#16615955] If the gate controller has a separate 24 V signaling output, that would be the easiest place to connect a different lamp [#16615955]
  • #1 16614447
    zyznos321
    Rate: 30
    I recently bought a led signal lamp for the gate on the Allegro, given in the subject. The lamp flashes in such a way that it goes out for a moment, and then it flashes for another moment like a strobe and so on. It is powered by 230v. Unfortunately, I am not satisfied with the amount of light that comes out of it. During the day and in the evening it is barely visible.
    I have a lot of 230v led bulbs and LED panels and strips for lower voltages. Someone can know if it is easy to change this system to make the lamp shine stronger.
    Thank you in advance for your help :)
    Flashing LED Signal Lamp 838: Enhance Brightness with 230V LED Bulbs, Panels & Strips Flashing LED Signal Lamp 838: Enhance Brightness with 230V LED Bulbs, Panels & Strips Flashing LED Signal Lamp 838: Enhance Brightness with 230V LED Bulbs, Panels & Strips Flashing LED Signal Lamp 838: Enhance Brightness with 230V LED Bulbs, Panels & Strips
    Update:
    I checked it quickly and the output for the diodes is a little over 5v (for each of the 4 strips).
    Is it possible to replace any resistor or other element and easily make it so that the output is 12 or 230v in order to mount other LEDs?
    goldi74
    Help: 1367
    Rate: 1539
    The LED current is set by the 180? resistors (181 marking) at the bottom of each LED strip. You can try to reduce their value, but you have to take into account a possible reduction in lamp life.
  • #3 16614520
    zyznos321
    Rate: 30
    It seems to me that it would be better to increase the current or voltage at the output of the circuit and completely change the LED strips to other ones, so as not to worry that they may turn off at any moment. Can it be done easily?
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3631
    You can add your narrower ones in the gaps between the original strips, supplemented with lossy resistors, but first check the supply voltage (e.g. on the legs of a large capacitor).
    Connecting the strips themselves to the existing LED poles is risky - there is some complicated connection of LEDs in series - parallel and the resistor is not too strong ...
    And be careful - depending on the polarity of the neutral and the phase, the full mains voltage may appear on the system.
    HD-VIDEO
    Help: 1265
    Rate: 1884
    There is a limited current there, because there is a transformerless power supply, and the value of the serial capacitor of this power supply limits the current also for LEDs.
    And this capacitor should also be replaced with a better quality one
  • #6 16615676
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    It is a typical lamp interrupter modeled on lucy nice or kiaro came. Instead of this LED miracle solder / mount the socket on the E14 thread and give a normal 25W bulb can be milky.
    I use a lot of automation and led lamps, I avoid it like a fire, because you can't see the carcass, the master is a beninca lamp with one led, visible only at night, and producers boast about energy-saving solutions with lamps as above or the ability to turn off the LCD display or LEDs on disc that download mW. :idea: Meanwhile, crap-quality transformers made by the Yellow River heat up to 100 degrees Celsius and eat several dozen W during idle operation.
  • #7 16615732
    zyznos321
    Rate: 30
    It seems to me that soldering the lamp holder alone will not do anything, because the LEDs in this lamp are powered by 5-6v. An ordinary 230v bulb will not shine as it should: /
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    If it is a 230V lamp, it is interrupted by a triac. So if you remove the led + series resistor + rectifier diodes (or whatever is there) it must work. You just need to know what you're doing.
    Here is the ancestor of this lamp:
    https://www.elektroda.pl/rtvforum/topic1943841.html
    https://www.elektroda.pl/rtvforum/topic3224080.html
  • #9 16615919
    zyznos321
    Rate: 30
    Ok, thx. Unfortunately, I do not fully understand what it is responsible for in this system, and I do not want to burn anything: /
    kotbury
    Help: 2100
    Rate: 3631
    No, not a triac. In this lamp, the flashing is controlled by the high-voltage Darlington ST901T transistor (photo), which is already located after the rectifier and there will be no specific modification of the board (replacing it with a triac inserted in front of the rectifier, and the rectifier itself must be converted to a two-diode one-wave bulb), it controlled a 220V mains bulb . (see the topic https://www.elektroda.pl/rtvforum/topic2532311.html at the end of the first post).
    You probably won't put a low-voltage bulb (let's say 6V) into the current system because its current efficiency is up to 100 mA. In fact, for the same reason you won't put in more powerful LEDs because this "power supply" will not do.
    So to improve the light or to use a 220V bulb (ordinary or LED), converting the control to a triac, leaving the existing system only to power the blinker or completely change the middle - e.g. the above-mentioned Nice Lucy 220V - the PCB even seems similar.
    And leaving aside the electrical discussions - we're about inserting light bulbs, and is this screw sticking out at the top not holding something? Because if it is needed for something, after converting it into a light bulb, you need to buy a holder for it.
    PS - does your control panel have no additional 24V signaling output? (most drivers have) - then without combining you connect a 24V bulb without any interrupter.
  • #11 16616870
    zyznos321
    Rate: 30
    Thanks for explaining everything. The screw is not needed for anything. The lamp is powered from the same output as the engine and it is convenient for me, because the driver can sometimes spin (e.g. when struck by lightning) and then the engine works (most likely to the right and left at the same time, because it stands still and makes a sound) . Thanks to the lamp connected to the same output, I can see that something is wrong and run to disconnect the electricity :)
    Most likely I will make the circuit breaker according to the instructions from the topic you provided. It will definitely be cheaper than buying a second lamp. By the way, I will learn to etch PCBs.
    Thanks again to everyone for your help :)
The discussion revolves around enhancing the brightness of a 230V LED signal lamp, specifically model 838, which the user finds insufficiently visible both during the day and at night. Suggestions include modifying the LED current by adjusting resistors, replacing the existing LED strips with higher quality ones, or using a standard E14 socket for a conventional bulb. Concerns about the lamp's power supply, which is transformerless and limits current, are raised, along with the risks of incorrect modifications. Users discuss the feasibility of using a triac for better control and the potential for DIY circuit modifications to improve performance. The user expresses intent to learn PCB etching for future enhancements.
