Samsung Galaxy J5 Root Issue: Stuck in SAFE MODE & Volume Down Button Not Working
odviati 4896 2
  • Can safe mode be disabled without volume down button
    #1 16623921
    odviati
    Hello, I have a problem with Samsung Galaxy J5 (after root).
    It looks like this: the volume down button does not work and the volume down button does not work. I have safe mode on all the time, there is no option to disable it by a new start, just like the message suggests. I bet that as it was written in another topic, there is probably a problem with the tape, but what is the point of disconnecting it if one button works and the other does not. And here comes my question: can you remove or block this mode?
  • #2 16624167
    nutergsm
    Help: 1034
    Rate: 1665
    No way. You need to fix the button.
  • #3 16624451
    badboy84
    Help: 1197
    Rate: 1486
    Once in one phone helped me remove the battery for a few minutes, you can try ;) but it doesn't guarantee that it will have any effect.
