Choosing the Right TV for PS4 Gaming in a 15m^2 Room, 4.8m Viewing Distance
Kajzre 3984 11
How should I choose a PS4 TV size and placement for a 4.8 m viewing distance with a budget of 3,000 PLN, while keeping input lag low?
At 4.8 m, a 65-inch TV is considered the practical minimum for PS4 gaming, although a suitable model would exceed the 3,000 PLN budget by about 1,500 PLN. [#16629727] A 60-inch Samsung 60J6240 is a realistic budget option, but its input lag should be checked before purchase. [#16629727] At this distance, smaller screens can make game subtitles, interfaces, and collectible details difficult to see. [#16629798] Moving the TV closer—ideally testing it at about 1.5–2 m from the sofa—is therefore a sensible alternative, and the recommended size should be verified experimentally. [#16636502] For gaming, disable image-enhancement features and calibrate the picture; one owner reported no noticeable input lag on the 60J6240 in dynamic games. [#16631300]
  • Need for larger diagonal and low input lag
    #1 16629710
    Kajzre
    Hello, please help me in choosing. First of all, I want to choose the right diagonal for such a distance (or maybe it's better not to stick to the wall and put a meter in front of the sofa somewhere on the table?) And low input lag (TV primarily for playing on PS4).
    1. How big is the room in which the TV is to be located? 15m ^ 2
    2. How far are we from the TV screen? 4.8m
    3. How many people sit in front of the TV? 2
    4. Are we sitting in front of the screen or also sideways to the screen? mostly straight ahead
    5. Should the TV stand or should it hang? I wanted to hang it, but it might as well stand
    6. How does the sun shine in the room? longitudinal windows the wall with an angle to the TV, good blinds
    7. What kind of TV do you currently have? lack
    8. What do we want the TV to have? no difference
    9. What signal will be connected to the TV? maybe NC +
    10. What devices? PS4
    11. How many hours a day should the TV work? about 6h
    12. Does it happen that you watch only one program for several hours? match approx. 2 hours
    13. What kind of programs do you watch the most? matches, movies
    14. Are you going to surf the internet? no
    15. Are you going to play games - if so, how many% a day? yes, 30-50%
    16. Brand Preference? lack
    17. Size preferences? lack
    18. What annoys you in TV sets? lack
    19. Do you watch more in the evenings or during the day? in the evenings
    20. To what maximum amount do you plan to purchase? 3000 PLN
    21. How often do you replace televisions at home? very rarely
    22. Do you use internet applications often? rarely
    Ludwik XVI
    Help: 1325
    Rate: 788
    At nearly 5m, the absolute kinimum is 65 inches. However, you won't see the details of the picture anyway.
    PLN 3,000 is not enough money for a 65 inch TV. There is a shortage of 1.5k PLN for the cheapest, sensible models.
    In your wake I only think of a 60-inch Samsung 60J6240 - look for the input lag, because I don't remember.
    It costs less than PLN 3,000.
    65-inch minimum for 5m viewing distance
    #3 16629798
    Fallen89
    Rate: 12
    It's true, and in the case of playing these 5m distances and few inches will disturb even more - poor visibility of the in-game subtitles, interface, details (e.g. all kinds of collectibles).
    So far, have you played with 5m or are you switching from the desk monitor to the TV? Because it cannot be denied that up to these 5m distances it is really a minimum of 65 "as nothing would be needed.
  • #4 16630159
    Kajzre
    So far, only a desk, a living room in a new apartment has such a layout that I have either a wall 4.8m away from the sofa or on a table right in front of the sofa, so a total of 32 "would probably pass the exam. I will test this Samsung again, thanks for help.
    groszekoki
    I had a similar dilemma, although the distance was closer, about 4 meters.
    I bought a Samsung 60J6240 last Thursday for less than PLN 3100 at Media Markt + PLN 360 Plus warranty (worth it).
    I have not observed Input lag, although you need to turn off the boosters and calibrate the image for games, and since I play relatively dynamic games, I can recommend this TV.
    Image of a razor from a distance of 3-4 meters :) everything flashes nice and pleasant.
    Rognor
    Help: 78
    Rate: 120
    Kajzre wrote:
    the appropriate diagonal for such a distance (or maybe it is better not to stick to the wall and put somewhere on the table a meter in front of the sofa?)
    Of course it's better!
    https://hdtvpolska.com/kalkulator-odleglosci/
    For your distance, 114 inches for 1080p and 228 inches for 4K are recommended.
    These are not just fingerprints! They are real, it takes the average eye to see ALL the details. As you can see the values are proportional, that is 2 times smaller distance 2 times less inches.
    So check EXPERIMENTALLY (on your monitor and maybe a larger TV). For example, for me the optimal was 90 cm for a 24 inch monitor (otherwise I had a problem with fast reading of 1080p letters), for the average eye it is 101 cm. And this is confirmed on larger screens: for 32 inches SD TV I watch from 2.5 m, and I play from 1.5 m (sometimes 1.2 m), and 42 inches was too much to see the screen. So 60 inches by 4.8 meters will do for SD (and often 720p), I doubt you would be able to read the letters (e.g. in a Hitman game).
  • #7 16641396
    Mariano11
    Help: 57
    Rate: 43
    55 inches with ambilight - it will be cheaper and the image will be visually larger :)
  • #8 16641635
    Kajzre
    I decided to borrow from my friend 32 "and check it on a table 1.5-2 m from the couch and then I will decide if one or a larger one is enough. By the way - what do you think about the Samsung E32J5200?
    Ludwik XVI
    Help: 1325
    Rate: 788
    Good entry model.
  • #10 16668373
    Mariano11
    Help: 57
    Rate: 43
    After all, it is 32 or 55 inches, because the difference is considerable :D
  • #11 16671709
    Kajzre
    Life has verified :D Earlier entries in this post confirmed my belief that even 60 "may not be enough, so I decided to put the TV in a different place.
  • #12 16672256
    Mariano11
    Help: 57
    Rate: 43
    So the TV will be needed or not :) ?
The discussion revolves around selecting an appropriate TV for PS4 gaming in a 15m² room with a viewing distance of 4.8m. Participants suggest that a minimum screen size of 65 inches is ideal for this distance to ensure visibility of details, especially in gaming contexts. The Samsung 60J6240 is frequently recommended for its low input lag and good image quality, with users noting the importance of calibrating settings for gaming. Some participants also mention testing smaller screens, like a 32-inch model, to assess comfort and visibility before making a final decision. The conversation highlights the significance of screen size, input lag, and viewing distance in enhancing the gaming experience.
TL;DR: At 4.8 m, a 65" screen is the minimum; "the absolute minimum is 65 inches." Budget 3,000 PLN falls short for many 65" options. [Elektroda, Ludwik XVI, post #16629727]
Why it matters: You’ll avoid unreadable HUD text, sluggish controls, and mismatched budgets when sizing and setting up a PS4 TV for a long viewing distance.
What screen size fits a 4.8 m viewing distance for PS4?
Aim for at least 65 inches. As one expert put it, "the absolute minimum is 65 inches." Larger screens help with UI text and fine details at this distance. If 65" stretches budget, consider moving the screen closer instead of shrinking size. [Elektroda, Ludwik XVI, post #16629727]
Is 3,000 PLN enough for a 65-inch gaming TV?
Expect to exceed 3,000 PLN for a sensible 65-inch model. The thread notes about a 1,500 PLN shortfall versus the cheapest viable 65" sets. Stretch the budget, find a sale, or opt for a closer placement with a smaller screen. [Elektroda, Ludwik XVI, post #16629727]
Will a 60-inch TV be too small at 4.8 m?
At nearly 5 m, 60 inches can make subtitles and HUD elements hard to read. One gamer warned that a few inches less worsens visibility of in‑game text and collectibles. Consider 65" or bring the screen closer to you. [Elektroda, Fallen89, post #16629798]
Should I wall‑mount or place the TV closer on a table?
Place it closer if the wall is 4.8 m away. Bringing a screen to 1.2–1.5 m for play can improve text readability and reaction comfort. The advice was clear: "Of course it's better!" to move it closer when distance is excessive. [Elektroda, Rognor, post #16636502]
Is Samsung 60J6240 good enough for PS4 gaming?
It can be. A buyer reported no noticeable input lag after disabling picture "boosters" and calibrating for games, even in fast titles. Image looked sharp from 3–4 m. If you must sit at 4.8 m, try to position it closer during play. [Elektroda, groszekoki, post #16631300]
How can I reduce input lag on budget TVs?
Turn off processing features (often called motion or contrast "boosters") and use a game‑tuned picture mode. Calibrate brightness and sharpness to taste. One player found the TV responsive for dynamic games after these tweaks. "Disable boosters and calibrate for games." [Elektroda, groszekoki, post #16631300]
Can 32 inches work if I sit 1.5–2 m away?
Yes, testing a 32" placed 1.5–2 m from the sofa was proposed to solve the long‑distance problem. This desk‑like setup can keep HUD text readable without buying a huge screen. Try borrowing a 32" first to validate comfort. [Elektroda, Kajzre, post #16641635]
What size does a distance calculator suggest for 1080p at 4.8 m?
Guidance shared from a calculator: about 114 inches for 1080p at 4.8 m, and roughly 228 inches for 4K. That ensures the average eye resolves full detail. This underscores why bringing the screen closer is often smarter. [Elektroda, Rognor, post #16636502]
What’s a quick pre‑purchase test to avoid buyer’s remorse?
Try this: 1) Borrow a 24–32" display. 2) Sit 1.2–2.0 m away and launch a text‑heavy PS4 game. 3) Check HUD readability and comfort, then extrapolate to your target size. The thread explicitly recommends experimental checks before buying. [Elektroda, Rognor, post #16636502]
Is a 55-inch with Ambilight a viable alternative?
Ambilight can make a smaller screen feel larger by extending perceived image beyond the frame. A 55" Ambilight suggestion aimed to maximize perceived size at lower cost. It won’t fix unreadable text at 4.8 m, but it boosts immersion. [Elektroda, Mariano11, post #16641396]
Any warranty tips for midrange gaming TVs?
One buyer added a ~360 PLN extended warranty on a sub‑3,100 PLN TV. Consider similar coverage if you game daily or keep TVs for many years. It adds peace of mind for panel or mainboard failures beyond the base term. [Elektroda, groszekoki, post #16631300]
How did the original poster resolve the placement dilemma?
They changed the TV location after realizing even 60–65" might not feel large enough at 4.8 m. Moving the set addressed the size‑distance mismatch without overspending. Placement often solves visibility more efficiently than upgrading size alone. [Elektroda, Kajzre, post #16671709]
