Decoding MCD Radio Navigation System in VW Lupo 1.2 3L Without Removal - Possible?
naruto29 8349 5
  • #1 16636290
    naruto29
    Rate: 35
    my Lupo 1.2 3L has a radio; exactly MCD and Radio Navigation System is coded; you need to enter the code.
    I have a question: is it possible to decode the radio without removing it? Are there any codes generally available?
  • #2 16636301
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6437
    Do you know the code?
  • #3 16636309
    naruto29
    Rate: 35
    Well, I don't know the code. This is a factory radio with a black and white display that is not the color of some models
  • #4 16636313
    Help: 1405
    Rate: 6437
    Then take the guys to the car code site.
  • #6 17844854
    AdEr01
    hello, how is this code
    Moderated By CameR:
    Reg. 3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
    Reg. 3.1.11. Don't post messages that add nothing to the discussion.
    Reg. 3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users.
    Reg. 3.1.17. Take care of the level of questions and discussions. Thank you.
