Huawei Y6 SIM Card Issue: No Service, Works on Other Phones - Troubleshooting Tips
miron68 5388 7
  • #1 16639723
    miron68
    Rate: 49
    Huawei Y6 no service. The card works on another phone, and everything else works.
  • #2 16639747
    DiZMar
    Help: 2892
    Rate: 6652
    Broken phone.
  • #3 16639965
    nutergsm
    Help: 1034
    Rate: 1665
    Check the phone with a different sim card. Check if you have the correct imei number.
    The phone didn't fall down, wasn't it flooded?
    DiZMar wrote:
    Broken phone.
    If he was fit he would not post on the forum.
  • #4 16640054
    miron68
    Rate: 49
    With another card, also the lack of service did not fall down, it was not flooded it happened suddenly.
  • #5 16640059
    DiZMar
    Help: 2892
    Rate: 6652
    Only a specialist with him in his hand can correctly diagnose, but not necessarily.
  • #6 16640296
    nutergsm
    Help: 1034
    Rate: 1665
    Did you check?
  • #7 16641312
    miron68
    Rate: 49
    No, because I don't really know what's going on with this number, describe how to check it.
  • #8 16641333
    mobista
    Help: 257
    Rate: 365
    * # 06 #. Where did you get the phone
The discussion revolves around a Huawei Y6 experiencing a "no service" issue, despite the SIM card functioning correctly in other devices. Initial suggestions include checking the phone with a different SIM card and verifying the IMEI number. The user confirms that the problem persists with another SIM and that the phone has not been physically damaged or exposed to water. Further advice indicates that a specialist may be needed for accurate diagnosis, and the user is prompted to check the IMEI number using the code *#06#.
