Replacing the cells in the Makita 24V screwdriver from NiCd to Li-Ion
N37 4803 3
  • #1 16655829
    N37
    I have a screwdriver and a 24V NiCd drill and driver, very little used and in great condition, but the packages with cells were lost.
    I can buy replacements and still have NiCd, but I happen to have 20 3.6V Li-Ion cells, unused. I decided to use them.
    I will use 6 cells,
    But I have a problem with charging. The original charging station is for NiCd, so it will not be useful, it will work, but if I forget to turn off, you know what will happen. So option number two is to mount the charger on the packet and simply charge it with a pulse charger. And here is the problem...
    I have never met Li-Ion 6S charging control modules, i.e. for 6 cells.
    They are on 1/2/3/4 and that's it.
    Without etch design etc., wouldn't it be possible to use such a module:
    https://abc-rc.pl/modul-ladowania-3s-12v
    And connect one to 3 cells, and another three to another, connect the outputs in series to receive 24 V and connect it as a power supply?
    I am a layman, I have no magical knowledge and I wonder if two packages connected in series can be safely used as one 24 V?
    Will charging with a 24V impulse charger be ok? Is there more tension then and what?
  • #2 16655981
    czareqpl
    Help: 196
    Rate: 580
    The maximum safe charging voltage for 6S is 6 * 4.2V.
  • Universal microprocessor charger for mixed battery packs
    #4 16717092
    tadgra
    Help: 15
    Rate: 55
    And in my power tools, I replaced the NI-CD batteries with LI-ION, because I use them quite rarely and whenever they were needed, the batteries were dead. As the batteries were different for individual devices, from 7.2 to 18 [V], I decided to buy a microprocessor charger to charge all cells. It also functions as a rectifier for charging Pb 5 [A] batteries - it recognizes the 6 or 12 [V] battery itself and an adjustable laboratory power supply. In the batteries, I connect the controller sockets to individual cells, which I lead outside the battery. Since I had the cells for free from disassembled laptop batteries, I calculated that when I buy such a charger, it would be as if I had to buy NI-CD cells for one equipment and I safely charge all the batteries with one charger. My charger can charge up to 6 Li-Ion cells. I think such options can be considered.
