I'm looking for TV 49 "-50" - Samsung or another brand? - PLN 2500
DomekGrabka 3018 9
Which 49-50 inch 4K TV should I buy for about PLN 2500-3000, and is the Samsung MU6172 a good choice compared with the MU64 series?
A good alternative is the Panasonic TX-50EX700E; if it is cheaper, then one of the Samsung models mentioned above is also worth considering [#16776409] Samsung’s 2017 MU61xx series should be approached carefully, because there is concern that it may use weaker PLS panels, while the older KU6400 series was viewed as better than the MU6100 [#16770978] One reply also says you need to check each Samsung model individually, because this year’s lineup may be worse than last year’s [#16772461] So for your budget and preference for a VA panel, the safest advice from the thread is to compare the Panasonic TX-50EX700E against the exact Samsung model specification before buying [#16776409][#16770978][#16772461]
  • #1 16769736
    DomekGrabka
    1. How big is the room in which the TV is to be located? 10m 2
    2. How far are we from the TV screen? 2-3m
    3. How many people sit in front of the TV? 1-2
    4. Are we sitting in front of the screen or also sideways to the screen? straight
    5. Should the TV stand or should it hang? be
    6. How does the sun shine in the room? max 4 hours from the west
    7. What kind of TV do you currently have? An old picture tube in this room :) / in the Samsung 46C6000 living room
    8. What do we want the TV to have? image quality, HDMI 3x, USB
    9. What signal will be connected to the TV? cable-mulitroom UPC Media CI + module, wi-fi, hmdi PC and occasionally PS3 "fifa"
    10. What devices? PC and PS3, external drive
    11. How many hours a day should the TV work? 6h
    12. Does it happen that you watch only one program for several hours? Yes
    13. What kind of programs do you watch the most? movies / series from UPC but most often from PC cda etc., little sport
    14. Are you going to surf the internet? I've never had a smart, I don't know. The PC will be connected to the TV.
    15. Are you going to play games - if so, how many% a day? 3h
    16. Brand Preference? rather Samsung but I'm open to suggestions
    17. Size preferences? 49-50inch 55 rather expensive
    18. What annoys you in TV sets? I hate long channel switching / replacing a broken matrix $$
    19. Do you watch more in the evenings or during the day? in the evenings - the VA matrix yes?
    20. To what maximum amount do you plan to purchase? 2500- maybe 3000
    21. How often do you replace televisions at home? very rarely
    22. Do you use internet applications often? no
    I was thinking about buying a Samsung UHD4K 49 "-50" from the 2017 series, that is:
    mu6102, mu6172, mu6402, mu6442, mu6452, mu6472
    From the previous topics, I concluded that the best choice for price / quality would be mu6172, I saw one for PLN 2400 in the promotion in the store. I do not know exactly what is the difference between this model and the mu64 models ** because if only a metal frame, I am not going to give PLN 3100 :)
    I am also open to your suggestions and suggestions.
  • #2 16770052
    chytysz
    I recommend samsung ku6640. It is true that it slightly exceeds the budget, but I am very happy with it and I have been using it for a year. Plus, it's a curved screen that not only looks cool in the room, but also a better movie-watching experience than flat glass. The quality of the displayed content is amazing.
    Added after 4 [minutes]:
    And the games play beautifully with the PS4 Pro too
  • #3 16770978
    DomekGrabka
    I'm not too passionate about curved TV, I'd rather put more money in picture quality.
    I just do not know if it is more profitable to buy a Samsung TV from the new 2017 series? or the 2016 series?
    I care about 50 inches and the VA matrix. Or maybe give up 4K and buy FHD?
    Louis XVI [in another topic he wrote]:
    "The KU6400 series is, in my opinion, better than this year's MU6100.
    49KU6400 was on sVA, in the MU61 series Samsung slowly returns to the weaker PLS matrices. I do not know how it will be in full size, but you have to watch out for the MU61xx series. "
  • #4 16772461
    Ludwik XVI
    Help: 1325
    Rate: 788
    Unfortunately, you have to check each of this year's Samsung models.
    I have the impression that it is even worse than a year ago ....
  • #5 16776270
    DomekGrabka
    And what 4k, 50-inch TV, up to PLN 2500-3000, could you recommend to me?
    Ludwik XVI
    Help: 1325
    Rate: 788
    Panasonic TX-50EX700E or how it should be cheaper is one of the Samsung indicated above.
  • #8 16781366
    DomekGrabka
    I have already managed to explain in Samsung 50mu6172 you can mount UPC Media CI + module.
    Does anyone know the page where you can check which VA or IPS matrices have Samsung TV?
    Actually the mu6172 model.
    Ludwik XVI
    Help: 1325
    Rate: 788
    Yes, it is real
The discussion revolves around selecting a 49-50 inch TV within a budget of PLN 2500, with a preference for Samsung or alternative brands. The user seeks a TV suitable for a 10m² room, viewed from 2-3 meters away, primarily for movies and series, with a focus on image quality, multiple HDMI ports, and USB connectivity. Recommendations include the Samsung KU6640, noted for its curved screen and excellent picture quality, although some users express concerns about the newer MU61 series models, which may feature inferior PLS matrices compared to the previous VA matrices. Alternatives like the Panasonic TX-50EX700E are also suggested. The user inquires about compatibility with UPC Media CI+ modules and seeks clarification on matrix types for Samsung TVs.
