Identifying 6203A Integrated Circuit in SOT89 Housing Used in LED Lamp with PIR Sensor
Jackziom 21927 7
  • #1 16664623
    Jackziom
    Help: 35
    Rate: 61
    Hello!
    I would like to know what the integrated circuit is. Unfortunately, I can't take photos at the moment but it seems to be in the housing SOT-89 (or twin). It works in an LED lamp with a PIR sensor. Personally, I suspect that this is a voltage regulator and a "driver" of LEDs.
    Below I put a preview drawing of the system (I also drew the manufacturer's logo, but I don't remember what the manufacturer is):
    I would be very grateful for any suggestions and help. Regards.
  • #3 16664875
  • #5 19181089
    maksmyk
    The full designation of this voltage regulator is ME6203A, and the company that produces this series is MICRONE.
  • #6 19181101
    DiZMar
    Help: 2894
    Rate: 6659
    The archaeologist appeared with his first post 9 years after registration.
  • A-marked part lacks CE certification
    #7 19181157
    maksmyk
    Letter A = no '' CE '', i.e. no certificate for the European Union. In addition, there are digits in the second row, which probably specify the voltage and current values, but it is difficult to decipher by illustrative list of the manufacturer. The voltage spread is considerable, but all models have low current efficiency.
    Moderated By Marek_Skalski:
    I invite my colleague to other topics, such current ones. ;)
  • Marking indicates non-CE part with unclear specs
    #8 19181214
    DiZMar
    Help: 2894
    Rate: 6659
    Note that the problem is 3.5 years old. Probably out of date for a long time and you are presenting your analysis here.
The discussion revolves around identifying an integrated circuit (IC) labeled as 6203A, housed in a SOT-89 package, used in an LED lamp with a PIR sensor. The initial assumption was that the IC functions as a voltage regulator and LED driver. A user provided a link to a Torex voltage regulator, but another participant pointed out that the markings did not match and suggested that the IC is likely from MICRONE, specifically the ME6203A model. Additional details about the IC's designation and its lack of CE certification were also discussed, indicating variations in voltage and current specifications across different models.
