Audi Navigation Plus requires Blaupunkt RNS A4 code 8d0 035 192 d
szefmuzyk 5064 11
  • #1 16664778
    szefmuzyk
    I need the code for the Audi Navigation Plus radio:
    Balupunkt RNS, A4 8d0 035 192 d
    auz1z1x3159939
    backup:
    0D775BFBF1A241F1C4A194FCBE8483E7
    56595C5F6265686B6E7174777A7D8083
    76797C7F8285888B8E9194979A9DA0A3
    Someone help?
  • #2 16665973
    bogege
    Help: 28
    Rate: 26
    Try the code 1443
  • #3 16670084
    szefmuzyk
    This code is not included ... other suggestions?
  • #4 16670210
    bogege
    Help: 28
    Rate: 26
    Have you tried in the car?
  • #5 16671723
    szefmuzyk
    Yes ... it tries 2 times and the code is wrong. How else to read the pin?
  • #6 16683241
    kav39
    [quote = "chef musician"] Hello,
    auz1z1x3159939
    backup:
    zmenit 3 strokes of the second dhamp.
  • #7 16684520
    szefmuzyk
    maybe someone will decode the code?
    • audi navigation plus b5.bin (4 KB) You must be logged in to download this attachment.
  • #8 16684861
    diddygy
    Rate: 14
    Code is 0263
  • #9 16685036
    szefmuzyk
    diddygy wrote:
    Code is 0263
    code is not correct ... my system navigation is connect in my home ... i plug in "+" Ub and "-" but it's not worked ...
    Added after 14 [hours] 37 [minutes]:
    Maybe something else needs to be attached?
  • #10 16686901
    bogege
    Help: 28
    Rate: 26
    szefmuzyk wrote:
    diddygy wrote:
    Code is 0263
    All codes are 100% correct!
    And you are wrong !! You need 3 X + 12V. Fis.rar (1.17 MB)You must be logged in to download this attachment.
  • #11 16687019
    szefmuzyk
    I was hooking up the radio in the car ... the code did not enter.
    after entering the code "0263" x2 I blocked the radio.
  • #12 16687123
    bogege
    Help: 28
    Rate: 26
    Check if you have these 3x + 12V in your car.
    It takes 1 hour to re-enter the code!
    Your programmer must be disabled from the radio!
✨ The discussion revolves around obtaining the unlock code for the Audi Navigation Plus radio system, specifically the Blaupunkt RNS model with part number A4 8D0 035 192 D. The original poster requests assistance in finding the correct code, providing various backup codes and details about their attempts to enter the codes. Several users suggest potential codes, including "1443" and "0263," but the original poster reports these codes are incorrect. There are also suggestions to check the wiring, specifically ensuring that three +12V connections are made, as this may affect the radio's functionality. The conversation highlights the challenges faced in decoding the radio and the importance of proper connections for successful operation.
TL;DR: Audi Navigation Plus (Blaupunkt RNS A4 8D0 035 192 D) needs 3x +12V feeds; “All codes are 100% correct!” Check wiring before retrying. [Elektroda, bogege, post #16686901]
Why it matters: This FAQ helps owners quickly unlock and power up RNS units without tripping lockouts.
Is the unlock code 0263 valid for this unit?
A forum decoder provided code 0263 for the posted AUZ serial and dump. Try it after proper power wiring. [Elektroda, diddygy, post #16684861]
Why would a correct code be rejected?
Insufficient power lines cause rejection. This RNS needs three separate +12V feeds. “All codes are 100% correct!” Check wiring first. [Elektroda, bogege, post #16686901]
How long is the lockout after wrong attempts?
After failed entries, the unit requires a 1‑hour wait before code entry reappears. Plan your retries accordingly. [Elektroda, bogege, post #16687123]
How many wrong attempts can trigger a block?
One user reported the radio blocked after entering 0263 twice. Expect a lockout and wait the required time. [Elektroda, szefmuzyk, post #16687019]
How do I power this RNS on a bench safely?
Follow this 3‑step wiring: 1. Provide three independent +12V lines to the required pins. 2. Connect ground solidly. 3. Only then attempt code entry. This prevents false rejections. [Elektroda, bogege, post #16686901]
I keep waiting, but the code screen won’t show—why?
A connected programmer can block code entry. Disconnect any programming interface or adapter from the radio, then power‑cycle and wait. [Elektroda, bogege, post #16687123]
Can I unlock it at home, or must it be in the car?
Home is fine if wired correctly. Ensure three +12V feeds and observe the 1‑hour timer before retrying a code. [Elektroda, bogege, post #16687123]
What is the “backup” or dump posted in the thread?
It’s a hexadecimal memory dump attached for decoding the PIN. The OP shared multiple dump lines for helpers. [Elektroda, szefmuzyk, post #16664778]
0263 didn’t work for me—what should I check next?
Verify the three +12V feeds first. Many “wrong code” errors trace to missing power lines, not the PIN itself. [Elektroda, bogege, post #16686901]
Any edge cases I should know before retrying?
If a programmer remains connected, the radio can ignore inputs. Remove it, power‑cycle, then wait the full hour before entering codes. [Elektroda, bogege, post #16687123]
Where can I confirm the exact model and serial on my unit?
Check the front label and top sticker. Example shown: RNS A4 8D0 035 192 D, AUZ1Z1X3159939. [Elektroda, szefmuzyk, post #16664778]
