Skoda Fabia I 2004 1.4 MPI: Electric Windows Malfunction, Battery Reset, Window Driver Location
foreverforyou20 15990 4
  • #1 16268614
    foreverforyou20
    Rate: 41
    Skoda Fabia 1.4 mpi.
    Hello, electric windows are not working. Left and right.
    An interesting fact is that when I remove the battery for 10 minutes and plug it back in, everything is ok for 5 minutes, after which the situation repeats.
    Is it the fault of the window driver?
    Where is he
  • #2 16268641
  • #3 16268649
    foreverforyou20
    Rate: 41
    The car was not connected to the computer yet.
  • #4 16449248
    adroit
    Rate: 59
    Skoda Fabia I 2005. I wanted to set the same topic to make it easier to repair. I thought maybe someone had the same damage. I have this car, 2 years, third damage with glass. If I fix it, I'll write what happened. best regards.
  • #5 16481693
    adroit
    Rate: 59
    I have repaired electric windows in my Fabia 2005.
    I dismantled the expansion joints in the left door and there was no good contact in the upper black plug on the plus (this is a red thick wire cable) I replaced the terminals on the plus and weight (red and brown wire) (Such from VW 2.8) and it works a few days without plea.
