[Solved] IKEA Induction Hob Discoloration: Surface Stains from Pan Use - Removal Tips & Tricks
damian126 23721 8
  • #1 16666074
    damian126
    Rate: 10
    Welcome to the induction hob from IKEA appeared discoloration look as if they were from below. The burns created during the use of the pan and such discolorations appeared underneath. How to remove it>? IKEA Induction Hob Discoloration: Surface Stains from Pan Use - Removal Tips & Tricks IKEA Induction Hob Discoloration: Surface Stains from Pan Use - Removal Tips & Tricks
  • #2 16666094
    Piotr2608
    Help: 851
    Rate: 4487
    Overheated plate. Well nothing is perfect. You have to learn to live with it or try to advertise a CD if it is under warranty.
    ZimTech Piotr Zimny
  • #3 16666120
    damian126
    Rate: 10
    Thanks for the answer. The plate is exactly a year and after a minute baking the pancake has overheated? Anyone have it?
  • #4 16666127
    Piotr2608
    Help: 851
    Rate: 4487
    IKEA = cheap to sell, expensive to sell.
    Most models except that this problem is not so visible on some.
    ZimTech Piotr Zimny
  • #5 16666134
    damian126
    Rate: 10
    It has a 5 year warranty. I wonder if it is worth advertising>?
  • #6 16666138
    Piotr2608
    Help: 851
    Rate: 4487
    You can risk it, I don't know how the guarantor will approach the matter.
    ZimTech Piotr Zimny
  • #7 16666149
    damian126
    Rate: 10
    Thanks for your help I will report it for warranty and we will see what comes out of it.
  • #8 17837632
    mortos
    I will refresh the topic - was it possible to advertise?
  • #9 17891441
    damian126
    Rate: 10
    Subject to close after a long time but managed to take advantage of the guarantee.
The discussion revolves around discoloration issues on an IKEA induction hob, attributed to overheating during pan use. Users express concerns about the appearance of stains and whether these can be removed. Suggestions include considering warranty claims, as the hob is under a five-year warranty. Some users note that discoloration is a common issue with certain models, while others share experiences of successfully claiming warranty service for similar problems. The conversation highlights the balance between product affordability and quality concerns.
