Braun Silk-epil 7 Epilator: Power Conversion for 240V Mains Operation & Charging Solution
jgx 11625 7
  • Mains operation not supported, only battery charging
    #1 16669310
    jgx
    Rate: 13
    I have such a problem - my wife has an epilator (now the warranty has expired, so I can combine) that works only from the battery, when connected to 240V, there is only charging - what should be done to make it work also on 240V, i.e. that it works on the mains and not only charging. The previous Braun model that my wife had, this is how the new one worked because of the possibility of epilation in water from the network, it only has charging
  • #2 16669927
    Kaliber PC - Service
    Help: 50
    Rate: 69
    In fact, you've already answered your question - you would have to completely redo the power section of the epilator that is, adjust the mains voltage to that of the battery and power this epilator with that. But that's an approach mega theoretical , in practice it is quite a serious change and it is even hard to clearly define how to do it exactly ... Straightening, filtration, noise suppression, good stabilization - this is the direction to follow, but with extreme caution at 230V . ;)
    The question is - what is the point of such a modification?
    Konstantego Damrota 5, Radlin, 44-310 | Tel.: 692XXXXXX (Show) | Company Website: https://www.kaliberpc-service.pl/
  • #3 16670909
    mariuszp19
    Help: 311
    Rate: 410
    But this epilator is powered by a power adapter, not directly from 230V. The point is that the epilator only works when the AC adapter plug is removed from the epilator socket. I have the same problem hence this post.
    And the point of reworking is that the internal batteries do not stand up to the full epilation process. And after some time, the process must be interrupted to recharge the batteries. And yes, after plugging into the power supply, you could continue epilation. Of course, epilation in the shower is not necessary then for obvious reasons.
  • #4 16671031
    Help: 50
    Rate: 69
    Comprehensive answer, all clear. ;)
    At least a piece ...
    (...) The point is that the epilator only works when the AC adapter plug is removed from the epilator socket. (...)
    ... intrigues me, because I have not yet come across a "daily use" device, which, when connected to the power supply, would not work normally and charge at the same time, but only charge. :| Maybe I have seen too little in my life, ehhh ...
    But to the point - are you saying it's powered by an AC adapter? At the beginning, it would be good to know the current / voltage parameters of this power supply and the rechargeable battery, and then combine it specifically with the conversion.
  • #5 16671105
    tata1
    Help: 43
    Rate: 260
    First check that it will work with the epilator plug plugged in, but do not connect the power adapter. Maybe there is just some simple circuit (or even a micro switch) that only checks for the presence of the plug.
  • #6 16671173
  • #7 16671211
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4260
    A typical socket for a coaxial power plug has a switch - I have a flashlight, in which inserting the charging plug disconnects the battery from the flashlight. It may even make sense that the voltage is slightly higher when charging, and could damage the inverter in the flashlight. A similar switch has headphone and speaker sockets ...
  • #8 16671360
The discussion revolves around modifying a Braun Silk-epil 7 epilator to operate directly from a 240V mains supply instead of relying solely on battery power. Users highlight that the device is designed to charge when plugged in but does not function simultaneously. Suggestions include examining the power adapter specifications, potential internal circuitry that may prevent operation while charging, and the need for a safe power supply. Concerns about safety and the complexity of modifications are emphasized, with recommendations to consider the current and voltage parameters of both the charger and the rechargeable battery before attempting any alterations.
