Modifying Apple iPhone Charger Cube for 48VDC Input Instead of 120VAC
225 6
  • #1 21663624
    Trevor Back
  • 48VDC input possible via bridge rectifier DC side
    #2 21663625
    Earl Albin
  • Clarifying power source and output requirements
    #3 21663626
    Chuck Sydlo
  • #4 21663627
    Trevor Back
  • #5 21663628
    Trevor Back
  • Boost 48V to 130VDC for simpler input mod
    #6 21663629
    Earl Albin
  • #7 21663630
    Trevor Back
The discussion addresses modifying an Apple iPhone charger cube to operate from a 48VDC input instead of its designed 120VAC input. The charger’s internal circuitry rectifies AC to DC, typically requiring about 130VDC after rectification for proper operation. Applying 48VDC directly to the DC side of the bridge diode may not start the charger or produce the 5V output due to insufficient voltage and possible undervoltage lockout. Rewinding the charger’s coupled inductor (transformer) to match the lower input voltage and adjusting the MOSFET current limit and device to handle increased peak currents and conduction losses are suggested but involve significant modification complexity. A practical alternative is to use a boost converter to step up the 48VDC to approximately 130VDC, simulating the rectified AC input voltage, allowing the charger to function without internal rewinding. Noise filtering considerations are also mentioned, as the charger operates at around 200kHz switching frequency, and input noise attenuation may be necessary. The user plans to test the boost converter approach and report results.
