[Solved] Electrolux Ergorapido Lithium LI-35 - The wireless vacuum cleaner does not charg
zkwiat 16065 3
  • #1 16758964
    zkwiat
    Charging does not work, nothing turns on. I am looking for help identifying the integrated circuit shown in the photo. Read on the chip 01760 PEm 1528A2 9594. I will be grateful for the hint, what is it?
    Electrolux Ergorapido Lithium LI-35 - The wireless vacuum cleaner does not charg Electrolux Ergorapido Lithium LI-35 - The wireless vacuum cleaner does not charg
  • #2 16775166
    zkwiat
    I think I misread the system symbol. This is not PEm but PBm.
    kancik70
    Rate: 12
    Hello, if current parts for this vacuum cleaner, including this transistor, are available in the TME Łódź shop
    Regards
  • #4 17156048
    zkwiat
    Problem solved :) Failed to identify damaged items.
    PSMN017-60YS.115 - N-MOSFET transistor;
    and Diode B540C-13-F.
    After regenerating pieces of burned paths and soldering in the above elements, the vacuum cleaner works :)
    I close the topic
