MyPhone Q-smart slim - What replacement for a swollen BM-07 battery.
Torx75 5976 6
  • Need a 3.8 V 1600 mAh BM-07 replacement battery
    #1 16675287
    Torx75
    Rate: 9
    Hi.
    Someone who can replace the BM-07 battery for the MyPhone Q-smart slim phone.
    The battery has swollen and has been disconnected by protection.
    On the case, the battery was described as "Li-ion 3.8V 1600mAh, 6.08Wh. Maximum charging voltage 4.35V ...".
    Dimensions ~ 63 x 55mm, thickness about 4mm.
    3 contacts on the right edge (+ extreme right).
    Best wishes.
  • #2 16675829
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    Why replace ?? After all, you can buy at a well-known auction site for pennies.
  • #3 16680570
    Torx75
    Rate: 9
    I haven't seen the BM-07 battery on a well-known portal yet and the manufacturer washes his hands.
    I wonder if something would fit from LG or picking a link and moving the contacts.
  • #4 16694823
    szpady666
    In Teletorium they should choose a replacement, they often have parts for myphones.
  • #6 16695016
    Torx75
    Rate: 9
    Thank you for the information.
    Regards.
  • #7 16730703
    pio1975
    Rate: 11
    Hello, I will add that I also have a problem finding the described battery BM-07
    Maybe some of my friends know where to buy a white crow :)
The discussion revolves around finding a replacement for the swollen BM-07 battery used in the MyPhone Q-smart slim smartphone. The original battery specifications include a Li-ion type with a voltage of 3.8V and a capacity of 1600mAh. Users suggest various options, including purchasing from auction sites, checking with Teletorium for parts, and considering alternatives from LG by modifying connections. One user successfully found a link to a new original BM-07 battery for sale. The challenge remains in sourcing this specific battery, as some users express difficulty in locating it.
