Samsung J3 2017 (SM-J330F / DS) - possible replacement of the same fast?
piotrd76 8748 6
  • #1 16680673
    piotrd76
    Automation specialist
    Help: 35
    Rate: 68
    Is it possible to exchange only the cracked fast (display and digitizer work) in OCA / LOCA / etc technology in this phone? I asked after GSM services and only make the previous version (J3 2016), in one they offered at most the replacement of a complete set of display, but the cost makes the repair unprofitable.
    I am asking for confirmation if it really is "not well enough" and there is nothing to look for?
  • #2 16680721
    makosuu
    Help: 369
    Rate: 370
    You can, but J3 2017 has an LCD screen, in which case the whole is exchanged. Buy yourself on Allegro or Aliexpress yourself and exchange.
  • #3 17031020
    Samuraj
    Help: 286
    Rate: 619
    Has anything changed in this matter?
    I see that there are offers of the same touch.
  • #4 17031205
    blahfff
    Help: 1036
    Rate: 1301
    There is still an LCD display inside, so if someone is doing the OCA method, it's possible. With LOCA there is a risk of flooding the backlight.
  • #5 17031690
    bogdan2491
    Help: 52
    Rate: 97
    The issue of the availability of parts and in OCA technology is the most feasible. J3 2017 as the only one from the Samsung family (by no means referring to popular models) got a superamoled LCD display instead of the display (unless I want to emphasize that it is a budget man) In any case, LOCA advise against
    I just noticed that the theme from September ... Then there could be a problem with the availability of parts, as the model was newly introduced to the market.
  • #6 17031906
    rabus40
    Rate: 14
    Of course, he will be able to replace the glass itself with OCA
  • #7 17032109
    makosuu
    Help: 369
    Rate: 370
    Yes of course
    But with LCD it may not be cost effective.
The discussion revolves around the feasibility of replacing only the cracked glass on the Samsung J3 2017 (SM-J330F / DS) using OCA or LOCA technology, given that the display and digitizer are functional. Responses indicate that while it is technically possible to replace just the glass using OCA, the J3 2017 features an LCD screen, which typically necessitates a full display replacement. Concerns are raised about the cost-effectiveness of such repairs, especially with the risks associated with LOCA, such as potential damage to the backlight. Availability of parts for the J3 2017 is also noted as a potential issue, particularly since it is a newer model.
