Quick Samsung Galaxy J5 (2017) Cracked Screen Replacement: DIY, Separator, Molybdenum Wire
Torada 4899 2
  • Safe DIY screen glass removal without a separator
    #1 16838036
    Torada
    I have a question regarding the replacement of cracked fast in Samsung Galaxy J5 (2017). Will he be able to replace it himself? If so, how to do it safely (I do not have a separator). The most important thing for me is to safely remove the glass from the display. Wherever I have a slightly cracked phone, the fast one has gone down, however, in a place where the whole phone is fast. I thought about warming the phone with a dryer and removing the glass with a molybdenum wire, although I do not know if it is safe. Best regards and hope for help and best regards :) !
    KamGr
    Help: 77
    Rate: 203
    If you are going to do it for the first time on a phone like this, better give it to someone who has an idea. This is not a simple operation and it is very easy to damage the display.
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Forget about home repairs on this display, even if you somehow put it together then you won't put the new glass on properly.
    Services with good equipment and very extensive experience sometimes have problems to do it correctly.
    Buying a new complete set only.
