Samsung Galaxy J3 display - Working touch but the display does not work
Vaxes 6057 12
Why is my Samsung Galaxy J3 screen mostly black while touch still works, and do I need to replace the display?
Yes — a mostly black screen with working touch and cracked glass points to a damaged LCD/display assembly that needs replacement. If the phone is under warranty, a free repair is unlikely because mechanical damage is usually treated as a warranty exclusion unless you have extra accident insurance [#16460606] One reply estimated the display price at about PLN 300 and suggested checking replacement prices on Allegro [#16460606][#16460684] An authorized service (for example, where you bought the phone) will usually cost more than a normal GSM repair shop, but it is the safer option if you want to keep any remaining warranty [#16460706] A regular GSM service is likely cheaper, and one reply said such shops may fit an original LCD and that warranty was still recognized in some Samsung/iPhone cases afterward [#16461346]
  • Diagnosing a damaged Galaxy J3 display assembly
    #1 16460538
    Vaxes
    Hello, I have a problem with the display. Almost the entire screen is black there are only 2 places at the top of the phone in the corners where there is something visible. However, touch probably works full screen because I can answer the phone. Is this display to be replaced? How much would it cost and where should it be best done (salon or some repair place etc.). And one more thing because actually I'm not sure if it was my fault the phone was lying in the bag someone could step on it or crush it but not in 100% so is there any sense to make complaints or rather better fix it?
    Robert 1960
    Level 32  
    Help: 238
    Rate: 408
    Hello, not much information, but if the phone is under warranty and you do not see any mechanical damage, you can always try to return to the service, it's free and maybe they will repair it, and if not repair it!
    P.U.T. DOMSAT
    Ignacego Rzeckiego 4/39, Lublin, 20-637 | Tel.: 697XXXXXX (Show)
  • #3 16460585
    Vaxes
    Well, the glass is cracked in 2 places, 1 is wide, however, it worked normally after this and 2 is tiny and nwm if it can be because I don't remember when I did it
    Replace the display; warranty likely excludes mechanical damage
    #4 16460606
    KamGr
    Help: 77
    Rate: 203
    From your description you can conclude that the display you have to replace 100% (you can paste a photo as it looks then it will be easier to tell). You can find the replacement costs on the Allegro website, you'll more or less know how much it will cost you. If the phone is under warranty and you return it with this damage, it will most likely come back with a refusal to replace it because of mechanical damage (unless you had additional insurance against such accidents).
  • Seeking the cheapest Galaxy J3 display replacement option
    #5 16460684
    Vaxes
    Rather, I had nothing extra and I have a subscription so I need to fix it somehow. From what I looked at, the price of the display is about PLN 300 only nwm where I have to mount it to Orange or to some ordinary store where they deal with such things. I would prefer to do it as low as possible. Well, I'm afraid that they will not accept me and I'm not too close to Orange so I do not want to go for nothing
    KamGr
    Help: 77
    Rate: 203
    If you repair it where you bought it (authorized service) you will definitely pay more than in any ordinary gsm service, but by repairing it at an authorized service center and having the papers you can keep the warranty (if you still have it).
  • #7 16460768
    Vaxes
    And the display I have to buy myself, e.g. at Allegro, can I buy it in such a gdize store, will they fix it for me?
    KamGr
    Help: 77
    Rate: 203
    They have parts on the website, you don't have to buy anything.
  • #9 16460782
    Vaxes
    Thanks so much for the help, it is a pity that this cannot be guaranteed, because it was not entirely my fault; /
  • #10 16460788
    KamGr
    Help: 77
    Rate: 203
    That is, you can try at the most, they will give it back to you in such a state you will not lose anything.
  • #11 16460807
    Vaxes
    Is this not paid? In addition, for just getting there is a waste of money and I say there are scratches on the glass, and it seems to me that someone just stood on this phone because it is for no reason that the display would not spill or something would happen to me
  • #12 16460823
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Vaxes wrote:
    There is a broken glass in 2 places
    So it's guaranteed and there is nothing to drive. The first better GSM service will be the best solution.
  • #13 16461346
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    It seems to me that if you take to the gsm service, they put on the original LCD (they will be cheaper than the authorized service) and you will not lose the warranty. I had a few cases with Samsung and iPhone where after some time something else fell after my lcd and the services recognized the guarantee.
The user is experiencing a display issue with their Samsung Galaxy J3, where the screen is mostly black but touch functionality appears to be intact. They inquire about the necessity and cost of a display replacement, as well as the best place for repairs. Responses suggest that the display likely needs replacement due to visible cracks, and while authorized service centers may be more expensive, they preserve warranty coverage. Users recommend checking local GSM repair shops for potentially lower costs and confirm that purchasing a replacement display online is an option. Concerns about warranty claims due to mechanical damage are also discussed, with advice leaning towards seeking repair rather than filing a complaint.
