Opel Zafira 2.0 dti 2001 - Injection pump controller error p1630
Naksa 24885 7
  • Pump dose reading is correct despite limp mode
    #1 16683771
    Naksa
    Hello, I am new, so I apologize in advance if not this section, or something I am doing wrong. Zafira 2.0 dti, after cleaning the intake manifold (it is not necessary to remove the injection pipes), I could not bleed the system, in the end it worked, unfortunately the car did not idle and did not respond to gas. Kts showed the pump error p1631 first, after removing the error p1630 popped up, the injection dose solenoid valve. I replaced the pump controller and the electromagnetic valve (taken out of the pump where it was operational), the car fires up to gas, but ... The check engine popped out, the car is in emergency mode, which removes the error, but it returns. Help !!!
    I will add that kts shows the correct dosage of the pump.
  • #2 16683807
    jokerro
    Help: 207
    Rate: 1146
    Then there is a problem in the pump, something I think that the donor was not fully functional
  • #3 16683896
    adam7009
    Help: 656
    Rate: 1635
    Naksa wrote:
    kts fixes the bug, but it returns
    this, ie ??? what?
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #4 16684001
    Naksa
    This one is p1630
  • #5 16684140
    adam7009
    Help: 656
    Rate: 1635
    Like the colleague above, the pump is not working.
  • #6 16684387
    Naksa
    Pump as a mechanical failure? Or more of an electronic problem? I found a guy on alledrogo who regenerates pumps comprehensively on original parts for a note of PLN 650, but with a one-year warranty, what do you think about it, because it's a bit strange for me.
  • #7 16684414
    adam7009
    Help: 656
    Rate: 1635
    pump controller defective
  • #8 16684943
    jokerro
    Help: 207
    Rate: 1146
    Naksa wrote:
    I found a guy on alledrogo who regenerates pumps comprehensively on original parts for PLN 650
    nice guy, he also adds to the business. Only for such do.
    electronic because mechanical
The discussion revolves around a 2001 Opel Zafira 2.0 dti experiencing issues with the injection pump controller, specifically error codes P1630 and P1631. After cleaning the intake manifold, the user faced difficulties in bleeding the system, leading to idle problems and a lack of throttle response. Despite replacing the pump controller and the electromagnetic valve, the vehicle remains in emergency mode with recurring error codes. Responses suggest that the problem may lie within the pump itself, either as a mechanical failure or an electronic issue. A suggestion was made to consider professional regeneration of the pump with a warranty.
