Volvo V40 I: Original Radio Locked OFF, Unlock & Input CODE - Waiting Time & Solutions
34788 8
  • Need the correct code entry procedure
    #1 16691156
    marek216
    Help: 1077
    Rate: 932
    Probably the 2h is on the radio and the radio counts down 2 hours. If the radio was turned off at the time, you could wait.
  • #3 16691803
    marek216
    Help: 1077
    Rate: 932
    I'm not suggesting anything - I'm writing how you should do it.
    You will do what you think is right - you can wait with the radio off the next day if you think that this will solve your problem.
  • #5 16691852
    Need ignition on and 30-minute wait for code entry
    #6 16691912
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Yes, it should be turned on, otherwise you will not be able to enter the code again.
    Usually, 30 minutes is enough.
    As you have it you can connect the charger to the car at this time so as not to discharge the battery.
    I do not know how it is with you, but usually it is not possible to turn on the radio without the key in the ignition.
    You need to get the radio code anyway.
    Try to remove the radio, sometimes the code is saved on the radio if there was data to decode.
  • #7 16691929
    andrzej20001
    Help: 1578
    Rate: 6670
    Turn it on and wait. Then code and game
  • #9 16706223
The discussion revolves around unlocking the original radio of a Volvo V40 I after it was locked due to incorrect code entry. The user initially disconnected the radio to install a different one but faced issues when reconnecting the original unit, which prompted a code lock. Participants clarified that the radio must be turned on for a waiting period (typically around 2 hours) to allow for code entry. It was suggested to keep the ignition on during this time to prevent battery discharge. Ultimately, the user successfully unlocked the radio by waiting with the ignition on for the required duration.
