What does an electrician-automation work like in a night shift?
Toms96 7983 17
  • #1 16698510
    Toms96
    Hi
    I would like to ask someone who works at UR, what is your night work like?
    Is something being repaired or is it such an on-call and you can get drunk? :)
    best regards :)
  • #2 16698516
    rollinstone
    Automation specialist
    Help: 36
    Rate: 30
    And would production during the day be different from production at night? (if we are talking about serious bets). The atmosphere is probably a bit looser (no management, etc.), but why do all this combination at the beginning of your professional career (as I assume after your previous topic)
  • Night shift is mostly repairs and machine changes
    #3 16698555
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Forget, you are either repairing what was started during the day, or something of your own in the workshop, or you change the machines or something breaks out.
    Generally, night is worse than daily. 'Cause you're not gonna jump out partially or get anything done.
    And the night work is good for h ... and the cat.
  • #4 16700580
    grzegorzw
    It probably depends on the plant.
    For me, there is no difference .. that is, removing failures and inspecting and repairing defects on machines that are idle.
    Night or day the same rule applies that the job is to be done.
    In practice, a nightstand is not equal to a nightstand.
  • #5 16701713
    bestler
    Help: 254
    Rate: 894
    It can be different, nights are statistically lighter than days' wages, but that's not the rule!
    I was in a plant, where night is a hard nut for maintenance, because one time, that a truncated staff (they only exhibited automation specialists, because the automation will take over everything), two that closed warehouses, worse access to parts and three, which are often worse in production, are often operated by "failures in various ways to rest or kimna. Sometimes it will be a parameter in the panel, sometimes they will block something mechanically, but there are also such rude plays that all ur night on equal feet is looking for a solution to the defect.
  • #6 16702640
    Sosenkka123
    I agree with the predecessors, night night is not equal. Sometimes you get lazy and sometimes you have to fight a breakdown all night, and then it's not nice. He works on maintenance in a medium-sized brewery and when there is a breakdown at night, due to the shortened staff, sometimes he doesn't even have anyone to consult with and you have to figure it out yourself. There is only an automatic and a mechanic on the night shift, so sometimes there is something to do.
  • #7 16702642
    bestler
    Help: 254
    Rate: 894
    Sosenkka123 wrote:
    Works on maintenance in a medium-sized brewery
    This noble new beer ... ... :)
  • #8 16707763
    Sosenkka123
    Yes, this is the brewery ... I recommend beer!
  • #9 16708158
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    What about disaster recovery? You push them to the next shift or someone is controlling that your shift is to do it.
  • #10 16711530
    Sosenkka123
    At night, you control yourself how the factory is standing all night, and it turns out that the next change will make you accountable.
  • #11 16711535
    bestler
    Help: 254
    Rate: 894
    One more important thing - if you work shifts, in eighths or twelve, you have a lot of free time for private studies, you can even run your business legally. It's a very big benefit to work shifts in ur - as long as you're good at what you do of course.
  • #12 16711770
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    And what does the team at UR look like, so does it work two electricians / automation specialists and two mechanics, does it depend on the factory? My main point is that two heads are better than one.
  • #13 16712154
    rollinstone
    Help: 36
    Rate: 30
    This is probably too general a question, Wojciech. I have been to start-ups in plants where there is a full team of 2 mechanics, an electrician and an automation specialist at night. And I have been to those where an automaton or mechanic stayed on the night
  • #14 16739439
    kosmos99
    Help: 338
    Rate: 820
    It's best to ask during an interview ;-)
  • #15 16751089
    Rkarcz
    Help: 81
    Rate: 43
    @ cosmos99 well, my colleague's attitude to work is right.
    Buddy, like you, you ask about something like that on the technical forum, where you like technology - this is automation - they have a passion, not an unpleasant duty .. Give peace ... :)
  • #16 16753734
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    I don't think we understood each other. My point is that not every problem can be solved in one shift, so the robot flies to the next shift and does anyone control it at all?
  • #17 16754027
    bestler
    Help: 254
    Rate: 894
    @Wojciech.. buddy, you do what you can, if you can, you remove the failure, if for some reason you can't do it, it's difficult - you call for support, you download colleagues from the day shift - the next time you will be smarter and you will do it yourself.
  • #18 16754111
    kosmos99
    Help: 338
    Rate: 820
    Sure it controls, downtimes are monitored and your assessment depends on it too.
    it depends on the plant.
Night shifts for electricians and automation specialists often involve maintenance tasks such as repairing machinery, troubleshooting failures, and conducting inspections. The workload can vary significantly depending on the plant's operational status and staffing levels. While some nights may be less demanding, others can require intense problem-solving, especially when staff is limited. Communication and collaboration with day shift colleagues are crucial for addressing unresolved issues. The experience can differ based on the specific plant environment and the team composition, which may include a mix of electricians, automation specialists, and mechanics.
TL;DR: Night UR often mirrors daytime tasks, but with lean crews. One brewery runs nights with 2 technicians; “you have to figure it out yourself.” [Elektroda, Sosenkka123, post #16702640]
Why it matters: Night-shift maintenance keeps production recoverable by fixing stoppages despite reduced staff, closed stores, and limited support. This FAQ is for electrician/automation techs evaluating night UR work and how to succeed on shift.
What does an electrician/automation tech actually do on a night shift in UR?
You clear breakdowns, perform inspections on idle equipment, and finish pending repairs. The rule is simple: get the job done. Expect the same technical standards as days, with more independence and fewer support options. Prioritize restoring production safely and documenting actions. [Elektroda, grzegorzw, post #16700580]
Is night shift easier than day shift?
Not guaranteed. One pro said nights can feel lighter, yet reduced staffing and operator errors make some nights harder than days. Expect trickier faults, parameter mishaps, and mechanical blocks from tired operators. Plan for slower parts access. “Statistically lighter... but that’s not the rule!” [Elektroda, bestler, post #16701713]
How many people are on a typical night UR team?
Teams vary by plant. An example brewery runs with two: one automation technician and one mechanic. Lean staffing means you may have no one to consult quickly. Build cross-discipline skills and keep escalation contacts handy. [Elektroda, Sosenkka123, post #16702640]
Can a plant staff only one automation specialist at night?
Yes. Some sites schedule a single automation specialist overnight, assuming automation covers most issues. This increases response time risk for mechanical faults and parts changes. Mitigate with robust spares and clear call-out procedures. [Elektroda, bestler, post #16701713]
Do you get parts and engineering support at night?
Often limited. Night warehouses may be closed, and support teams off-site. This can extend downtime or force temporary workarounds. Plan ahead: stage common spares, label panels, and keep updated parameters and backups. [Elektroda, bestler, post #16701713]
Who controls unfinished repairs or disaster recovery across shifts?
Downtime is monitored. Your performance links to how you manage and hand over outstanding issues. Provide a clear log, status, and next steps so the next shift can continue without rework. [Elektroda, kosmos99, post #16754111]
What if I can’t fix a fault alone at night?
Escalate. Call for support or request colleagues from the day team when justified. “You do what you can; next time you’ll be smarter and do it yourself.” Document symptoms and tests to speed help. [Elektroda, bestler, post #16754027]
Is the night shift an on-call where you can relax?
No. Expect ongoing repairs, planned changeovers, or sudden breakdowns. One veteran noted nights are often tougher because you can’t “jump out” for help or parts. Stay alert and sober; safety and uptime depend on you. [Elektroda, Strumien swiadomosci swia, post #16698555]
What happens if the factory is down all night? Who’s accountable?
You are. At night you self-manage. If the plant stands, the next shift will hold you accountable for the status and handover quality. Keep precise downtime notes and corrective plans. [Elektroda, Sosenkka123, post #16711530]
How do I handle a night‑shift breakdown effectively?
  1. Stabilize safely: lockout/tagout, verify energy isolation, and capture alarms.
  2. Restore minimally: apply the fastest safe fix to resume production.
  3. Handover: log root cause, temporary measures, and parts needed for day shift. [Elektroda, kosmos99, post #16754111]
What are the upsides of working shifts in UR?
You gain larger blocks of free time for formal study or building a legitimate side business, if policy allows. This can accelerate career growth and certifications while maintaining income. Mastery increases autonomy on nights. [Elektroda, bestler, post #16711535]
Do operator errors really cause night breakdowns?
Yes. Reports cite operators using “various ways to rest,” leading to wrong panel parameters or mechanical blocks. UR may spend hours finding and reversing these changes. Train operators and lock critical settings. [Elektroda, bestler, post #16701713]
What is CAN bus?
Controller Area Network (CAN) is a robust two‑wire serial bus for real‑time communication between controllers, sensors, and actuators in machines and vehicles. It features prioritized arbitration and error handling. [CiA, 2023]
What is Arduino Nano?
Arduino Nano is a compact microcontroller board (e.g., ATmega328P variants) used for embedded control, prototyping, and education. It offers digital/analog I/O, PWM, UART, SPI, and I2C in a small footprint for panel or breadboard use. [Arduino, 2023]
What is Tuya?
Tuya is an IoT platform that provides cloud services, modules, and apps to connect and manage smart devices, enabling remote control, scenes, and analytics across brands. [Tuya Docs, 2023]
What is OpenBeken?
OpenBeken is an open-source firmware for Tuya‑style Wi‑Fi/BK72xx devices that replaces stock firmware to enable local control and custom automation without cloud dependency. [OpenBeken Docs, 2024]
Should I ask about night duties during the interview?
Yes. Ask directly about night responsibilities, staffing, parts access, escalation, and KPIs. Even forum veterans recommend clarifying this during hiring to avoid surprises. [Elektroda, kosmos99, post #16739439]
