Opel Vectra C - air supply panel - a problem with the air supply and air conditi
popek9 20313 5
  • #1 16698736
    popek9
    Rate: 26
    Car: Opel Vectra C, 1.9 MPi CDTi Z19DTH, 2005 (op-com detects it as 2006), CD70 radio
    I have a problem with the air supply panel (air conditioning - an automatic dual zone climate system). The old panel was damaged during cleaning in an ultrasonic cleaner, someone poured into the washer too invasive fluid and the panel stopped working at all. Before washing the panel in the car, the fan was able to turn itself on and discharged the battery despite the lack of a key in the ignition.
    I bought a new one, but after connecting nothing has changed. The backlight does not work at all, the on-board computer does not detect it either, because there are no options for changing the temperature. Mirror and rear window heating can not be turned on. Zero reaction on pressing the buttons.
    After connecting the op-com has detected a problem with communication of the air conditioning module, the error codes are u2207 and u2208. Clearing the errors does not help, they appear back when they are re-scanned.
    All fuses in the car are operational, only the relays have not checked. The radio and the rest of the equipment in the car work properly.
    Has anyone an idea what else I can check? Maybe someone has an electrical installation diagram of two cubes, which plugs into the air supply panel?
  • #2 16698752
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Why did you clean this panel?
    Added after 57 [second]:
    But the panel turned on or blow because it's important?
  • #3 16699185
    popek9
    Rate: 26
    I cleaned it because the central knob and left from the temperature did not always work as I squeezed it.
    if I remember correctly, the air supply and diode of the car button were turned on. Nothing else on the panel was shining.
    I forgot to add earlier that during executive tests in op-com there is air supply, flaps and even panel backlight.
    From what I have heard, these panels are plug & play and do not need a car login, is this really true?
  • #4 16699273
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Maybe it will help you.
    First check if the panel has power.
    XC25 plugin:
    pin 15 - mass
    pin 16 - plus.
    The appearance of XC25 and XC26 plugins
    Opel Vectra C - air supply panel - a problem with the air supply and air conditi Opel Vectra C - air supply panel - a problem with the air supply and air conditi
    Attachment diagram.
    You have two CANs there that go to the display - TID / BID / GID / CID depending what you have installed there.
    Where did you find the errors you wrote about - in which driver?
    You wrote about the lack of communication and you can do a test of exits - something does not fit here.
    • VECTRA C Klima.pdf (12.47 KB) You must be logged in to download this attachment.
  • #5 16845108
    wujekprokocim
    Hello!
    There are two plugs practically identical with the climateronik, only one blue and the other black. XC25 is that which, and XC 26 which? Because you can guess the description of these plugins.
  • #6 16845789
    Pawel wawa
    Help: 1262
    Rate: 4432
    So check on both, it's a problem?
