Calculating Mean, RMS Value, Shape & Peak Factors for Periodic Signals: Integral Square Solution
szymon1965 5724 2
  • Need help calculating RMS from the waveform integral
    #1 16710558
    szymon1965
    I have a task where I want to calculate mean value, effective value, shape factor, and peak factor from a periodic graph.
    I found formulas for particular tasks on the Internet. I calculated the mean value, in which I calculated the integral value as the difference of the areas of the two rectangles above and below the axis.
    The problem begins with the RMS value, where you want to find the integral square of this waveform. I am asking for help in calculating the effective value.
  • #2 16711151
    Zielonka
    Help: 55
    Rate: 45
    Here is the solution to your problem link
    best regards
    WB
  • #3 16711815
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    just plot the square of this waveform, zero squared is zero, constant squared is also a constant.
    best regards
