Calculating RMS Value of a 2V Amplitude, 2s Period, 50% Duty Cycle Square Wave
elektrokiler 27056 11
How do I calculate the RMS value of a 2 V square wave with a 2 s period and 50% duty cycle?
The RMS value is 1.41 V, not 1 V. For a 50% duty-cycle rectangular wave, the effective value is found from the heating effect: over 2 s, the waveform is 2 V for 1 s and 0 V for 1 s, so the equivalent DC voltage satisfies (U^2/R)·2 s = (2^2/R)·1 s, giving U = 2/√2 = 1.41 V [#1880578] The integral form gives the same result: U_rms = sqrt((1/T)∫u^2 dt), and with duty cycle d = 0.5 this becomes U_rms = Umax·√d [#1885885][#17245805] The 1 V result mentioned in the thread is the average value, not the RMS value [#1880130][#1880578]
  • #1 1880103
    elektrokiler
    Help: 13
    Rate: 9
    Question as above. Amplitude Um=2V, period T=2s, duty cycle 50%.
  • #2 1880130
    Filip
    Help: 34
    Rate: 54
    total from ) to T UM/T dt == 1V
  • #3 1880144
    elektrokiler
    Help: 13
    Rate: 9
    Are you sure? The RMS formula for any periodic waveform looks a little different.
    Aleksander_01
    Help: 1167
    Rate: 3435
    Colleague Filip calculated well ... but the average value of the voltage.
    From the definition of the rms value, this voltage (a rectangle with a duty cycle of 50%) must give off the same amount of heat as a DC voltage in the same period (I messed up a bit, but I'll give you a picture below that will explain everything). So P=U*I, I=U/R that gives P=U^2/R, and the heat generated is energy, so we multiply the power by time, which in our case is 2 seconds. It was for direct current.
    Now we calculate for a rectangle with a filling of 50%, i.e. for one second we can assume the waveform as a constant voltage of 2 V.
    The thermal energy generated in both cases must be equal, so (U^2/R)*2seconds = (u^2/R)*1second (the second second is zero, so we don't take it into account). Now simple mathematical relations and we get the formula U=u/2^0.5, which means that the rms value of a square wave with a duty cycle of 50% and an amplitude of 2 V is 1.41 V.
    or
    U=((1/T)*integral from 0 to T zu^2 after dt)^0.5 (for more advanced).
    We associate the average value of the current with the amount of flowing charge, i.e. with the surface area in a given period.
    We associate the effective value with the heat generated in a given period.
    Goodbye (it's nice to go back to school)
    • Calculating RMS Value of a 2V Amplitude, 2s Period, 50% Duty Cycle Square Wave wartość skuteczna.jpg (15.2 KB) You must be logged in to download this attachment.
  • #5 1881187
    octanq
    In my maths terms, the rms value is the average of the absolute value of the function** (I change all negative values to positive ones), i.e. in this case in the U[V]-t[s] axis system:
    from t=0 to t=1s: U is constant and equals 2V (U=Um=2V),
    from t=1s to t=2s: U=0, ***
    change all negative values to positive ones (remains unchanged)
    and now I calculate the average normally, so in this case the average will be 1V, because for the first second it was 2V, and for the second: 0V.
    ** this def. is equivalent to the formula given by Aleksander_01 (squared first, then square root - positive values remain);
    *** I'm not sure if this is how the waveform looks like, but I'm giving the principle (isn't it about alternating current?);
  • #6 1881333
    jony
    Electronics specialist
    Help: 1823
    Rate: 885
    And I always thought that the RMS value of a symmetrical square wave with 50% duty cycle equals its amplitude, which is 2V
    • RMS.doc (43 KB) You must be logged in to download this attachment.
  • #7 1881374
    Aleksander_01
    Help: 1167
    Rate: 3435
    Jony I read your previous posts and you seem like a sensible guy, and here is this post. You probably haven't thought about what you're writing, after all, it's not about a symmetrical waveform (then, yes, the rms value is equal to the max value, i.e. in our case 2 V). Look carefully at your attachment (last item - square wave).
    I'd like to believe that you just made a mistake, which happens to everyone.
    Your previous posts prove that you have proper knowledge (and here's a gaffe).
    Regards
  • #8 1881428
    jony
    Help: 1823
    Rate: 885
    Yes Aleksander_01 you are totally right my mistake :cry: sorry. The effective value is 1.41
  • #9 1885804
    elektrokiler
    Help: 13
    Rate: 9
    I didn't express myself very clearly, but my friend Aleksander_01 understood what the mileage was (unsymmetrical). Before I wrote this post, I counted from the formula (integral over the period under the root), which was also given by my colleague Aleksander_01, but somehow I get a different result. Could you show what and how?
    Aleksander_01
    Help: 1167
    Rate: 3435
    I figured if it was symmetrical it wouldn't be a problem.
    You know the formula, then we substitute: for T we substitute 2 because the period lasts 2 seconds, we write the integral from zero to T / 2 (that is one second, we only care about this part of the waveform), then it is u^2 so for u we put 2 because the amplitude is 2 V. And we count. And it comes out 2^0.5.
    You can create the pattern yourself, you just need to know the principle that I described in the previous post. In your case, it will be: PT=pT, ((U^2)/R)T=((u^2)/R)T/2 and from this equation comes this integral.
    Regards
  • #11 1890634
    elektrokiler
    Help: 13
    Rate: 9
    Thanks a lot buddy Aleksander_01 . I'm not very good at math and this is where it showed itself...
  • #12 17245805
    ryszard1955
    Help: 34
    Rate: 22
    In sum:
    Usk=Root(dT/T)*Umax where dT/T is the duty cycle, Umax is the amplitude
The discussion revolves around calculating the RMS (Root Mean Square) value of a square wave with a 2V amplitude, a 2-second period, and a 50% duty cycle. Various participants provide insights into the calculation methods. The RMS value for a square wave with a 50% duty cycle is derived from the relationship between the power dissipated in a resistive load and the effective voltage. The consensus is that the RMS value is approximately 1.41V, which is calculated using the formula U = Um / √2, where Um is the amplitude. Some participants initially confused the RMS value with the amplitude, leading to clarifications and corrections throughout the discussion.
