Seat Ibiza 6L 1.4 16V BBY 04r - Poorly starts after a night, longer standing.
11151 7
  • #1 16712616
  • #2 16713394
    krzysztofgerald
    Try to adjust the engine speed again.
  • #3 16713405
    sk700
    Help: 173
    Rate: 420
    A screw on the carburetor? Mercy...
    Is LPG available?
    In sequence:
    - reading errors
    - reading of parameters on a cold engine, especially temperatures
    - fuel pressure measurement during start-up.
    pablosek2 wrote:
    And while driving, the revs can hang at 1000RPM when the car is hot (driving in a traffic jam)
    While the car is still rolling? How is it normal.
  • #4 16713655
  • #5 16714143
    sk700
    Help: 173
    Rate: 420
    pablosek2 wrote:
    As for the measurements on the site, not everyone wants to do it. Read only and to delete the client.
    Realia, let me add that not everyone can correctly interpret the results. You need to find someone who is overwhelmed by such things because in the dark you can replace half the car and the problem will still remain.
  • Cold-start stall persists despite sensors and fuel check valve
    #6 16767553
    boruwa61
    Rate: 9
    Hello, I have a similar problem with the seat ibiza 6l 16v 2009 bxw engine.
    In the morning, it starts up about 500 revolutions and the second one goes out is fine. Only after 5-6 hours standstill, the same thing again. 2 temperature sensors replaced. At the mechanic, they put a check valve on the fuel line, it did not work, the fuel pressure is normal, about 3bar, I did not pay anything but asked for a phone call or something changed. I have LPG but I turned off and drove two days without gas and it was the same.
    I am asking for help or information on a mechanic from the vicinity of Katowice who likes unusual challenges.
  • #7 17307943
    luk0708
    Has the problem been resolved? I have the same.
  • #8 17311156
    boruwa61
    Rate: 9
    the fuel pump was to blame after replacing everything ok
The discussion revolves around starting issues with a Seat Ibiza 6L 1.4 16V, particularly after long periods of inactivity. The user reports that the engine struggles to idle correctly, initially dropping to 500 RPM before stabilizing at 1100 RPM. Despite replacing components such as the throttle, ignition coils, and spark plugs, the problem persists. Suggestions include checking the engine speed adjustment, reading error codes, measuring fuel pressure during startup, and ensuring proper interpretation of diagnostic results. Another user shared a similar experience, indicating that a faulty fuel pump was the cause of their issues after extensive replacements.
