LG G4C Phone Issue: Incorrect Battery Message, New Battery Doesn't Fix, Need Help & Ideas
DJF1 10122 7
  • #1 16715733
    DJF1
    Rate: 105
    I have a problem with this phone, I got a phone call from a friend because it can't be repaired. After switching on the crossed-out battery and the message '' incorrect battery ''. When the phone starts, it switches off with the same message after a short while. Soft uploaded and still the same, new battery still the same. Anyone have any ideas?
  • #2 16715745
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Did you turn it on under the charger is charging? On your phone off.
  • #3 16716771
    DJF1
    Rate: 105
    No charging under the charger, wrong battery. I haven't actually added this information
  • #4 16716775
    Pedros050
    Help: 2471
    Rate: 3926
    That's what I thought. Chinese counterfeit.
  • #5 16717020
    DJF1
    Rate: 105
    Do you think I would post this post if I did not check these options? Yes, the second battery was Chinese, but I had a second LG in my hand that was functional and I put the original battery out of it. The same effect '' wrong battery ''
  • #6 16751192
    DJF1
    Rate: 105
    I looked a little and found information that apparently when I upload a soft kitkat it will be all ok. I was looking and I did not find this version for this phone model, maybe someone will help because it is a shame to throw the phone in the trash because it is in good condition.
  • #7 16820498
    puzon92
    Rate: 11
    I have an LG Stylus 2 phone and it has a swollen battery in it, Plus replaced it with a new one but the message "wrong battery" is showing on this new battery. my version of the software is pure, unbranded soft V10c-EUR-XX, my friend has the same phone, only that with Play soft, V10c-260-06 and everything is ok when I put this new battery on. When I put its batteries in my phone, it is the same message again. He certainly has the original battery because he has not replaced it yet and was taking a new phone.
  • #8 18191429
    DJF1
    Rate: 105
    I return to the topic, the previous patient went to parts, but I have another with the same defect. Under the charger it shows a message but it starts and you can see that it is charging, reset and the message '' wrong battery '' and so it turns on twice and then it turns on and until it turns on and works with blanking it works. I will unplug the charger and after a while '' wrong battery '' and reset. Is it soft or motherboard, does anyone have any advice? Rather, the fault of the battery falls off because the second is the same
The discussion revolves around an LG G4C phone experiencing an "incorrect battery" message, which persists even after replacing the battery with a new one. The user reports that the phone shuts down shortly after startup, despite attempts to soft reset and using a second battery, which was also identified as a Chinese counterfeit. Other users suggest checking if the phone is charging properly and mention similar issues with other LG models, such as the LG Stylus 2, where a "wrong battery" message appears after battery replacement. The original poster is seeking a specific software version (KitKat) that may resolve the issue, indicating a potential software or motherboard fault.
