Fiat Tipo Estate 2017 - Description of the fuses under the dashboard
qvadratova 8691 2
  • #1 16717050
    qvadratova
    Rate: 24
    I am looking for a description of the fuses in the box under the dashboard on the left side of the steering column in the new tipo.
  • #2 16717136
    1 PAWEL
    Help: 674
    Rate: 1364
    2017 Fiat Tipo 5Door / Tipo Station Wagon - User Manual - no description?
    There is no description under the cover of the box?
  • Seeking always-on fuse for dash camera power
    #3 16723327
    qvadratova
    Rate: 24
    under the hood there is a description under the cover of the fuse box, but I mean the box under the dashboard. There is no lid and the manual describes only a few of them ...
    I am looking for a fuse which has voltage on all the time even after removing the key from the ignition switch and the voltage does not disappear at the time of starting (like on a cigarette lighter).
    Or maybe other suggestions where I could connect the power to the camera so that it could record all night in the parking lot ...
