[Solved] Golf 5 Plus Fuse Box Description: 1.9 BKC 2005 - Driver's Side Interior Fuses Guide
gacek7890 14508 2
  • #1 17222335
    gacek7890
    Hello, I am looking for a description of the fuses inside under the driver's side of the box for golf 5 plus because the ordinary five have the side
  • #3 17248481
    gacek7890
    Problem solved fuses all work turned out that the yoke in the h7 bulb burned out you can pull these wires out of these burnished outlets extend the cables and in the handle of the bulb to drill holes to move the cables plugged. Insert the bulb and the subject
