Seeking Fuse Box Layout for 2006 Grande Punto 1.3mj 90HP Version
skaktus 149922 6
  • #1 16404008
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    I am looking for a description of fuses in GP 2006, version 1.3 mj 90 km. It does not work for me, it's the first thing and the second thing is to know what's where. I have instructions, but there the description is for a completely different box than in my case. How would anyone of you have information about info.
  • #2 16404092
    leonov
    Help: 1039
    Rate: 2248
    And this is not this link ? from the first link?
  • #4 16404180
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Thank you, you're right, that's it. I decided to take it and the babol came out in the box - I know that the car was hit. As a result of the impact, it turned out that someone was rummaging in a box and combining with relays. Now a question arises about the description of relays and the use of sockets in the car. But to the point - in the photos I show which relay was combined and made "briefly". Will you help in the description of relays?
    Under the fuse box / relays there are 3 blue sockets. I have used two of them, one is unused and unblinded, and I do not think it should be that way. Do you know what these nests are for?
  • #5 16404806
    KarizmoGSM
    Help: 95
    Rate: 292
    I would advise you to dump this wire and put in a can, the bundles will often pull better, but do not connect further, sure nothing should be there, as did the wire cutting, and probably the cap plugged.
    KariMax Paweł Kalkowski
    Kronikarska 8, Łódź, 92-624 | Company Website: www.cfiat.pl
  • #6 16404931
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    I have already ordered a new box. I am asking for help in the description of the relays.
  • Airbag sensor mounted on bonnet strap
    #7 17216071
    tzok
    Help: 3176
    Rate: 6549
    It's with a yellow plug and cable, it's a sensor from airbags and should not be there, just screwed to the front strap around the bonnet.
    FUSE
    MARK CIRCUIT AND
    F2 Body Computer 60
    F4 ABS pump 40
    F5 ABS solenoid valves thirty
    F12 Motor motor heater (low and medium speed) *
    F13 Motor electric fan (high speed) **
    F14 Low beam left 10
    F15 Right passing beam 10
    F16 Left-hand traffic light 10
    F17 Right-hand traffic light 10
    F18 Electric car interior 40
    F20 Motor control unit 7.5
    F23 Robot gear box and shift lever 7.5
    F24 Control of the air conditioner, air conditioner control unit, control of window lifts, mirror adjustment 7.5
    F25 Available
    F27 Engine control secondary loads (oxygen sensor, EGR, canister, etc.) 15
    F28 Engine control of the main load (coils, injectors, etc.) 15
    F29 Motor control unit 10
    F30 Fuel pump 15
    F31 Front fog lights 15
    F32 Headlight washers thirty
    F33 Sound signals 15
    F34 Compressor activation 7.5
    F35 Start relay thirty
    F36 Bipower system valves 7.5
    F37 Robot electric pump. gearbox thirty
    F38 Controlling the air conditioner, air conditioner control unit 7.5
    F39 Robot gear box and shift lever 15
    F43 Motor control unit 7.5
    F54 Lighter socket 12V 20
    F59 Reverse switch, debimeter, water presence sensor in the diesel fuel filter, glow plugs (JTD only) 10
    F69 Defrosting the rear window thirty
    F70 Defrosting external rear-view mirrors 10
    F85 Right window windshield 20
    F86 Window windscreen left 20
    FS2 Available
    FS4 Available
    (*) 20A, 30A by 40 A, depending on the version
    (**) 30A, 40A by 60 A, depending on the version
    RELAYS
    MARK CIRCUIT AND
    T1 Motor electric fan (low speed) 50
    T2 Motor electric fan (high speed) 50
    T3 road 20
    T4 passing 20
    T5 Power supply "via the ignition switch" 50
    T6 Power supply "via the ignition switch" thirty
    T7 Motor control supply thirty
    T8 Fuel pump 20
    T14 Front fog lights 20
    T15 Headlight washers thirty
    T16 Sound signals 20
    T17 Compressor activation 20
    T18 Power supply "atboot " thirty
    T19 Bipower system valves (N / C) 20
    T20 Motor electric motor (average speed) 50
    T32 defrosting 40
    T40 Front window lifters thirty
The discussion revolves around the fuse box layout for a 2006 Fiat Grande Punto 1.3 MJ 90HP. The original poster seeks a detailed description of the fuses and their functions, as the provided instructions do not match their fuse box. A helpful link to a relevant schematic is shared, which the poster confirms is useful. The poster later reveals issues with the relay configuration due to previous damage from an accident, prompting a request for relay descriptions and the purpose of unused sockets in the fuse box. Additional responses provide insights into specific fuses and their functions, including details about airbag sensor wiring and recommendations for handling damaged wiring.
