Renault Master 2011: Fuse No.17 Keeps Blowing After Ignition Switch - Causes & Solutions
ossi_cw 25506 4
  • #1 16726217
    ossi_cw
    Hello!
    I would like to know what the fuse No. 17 is from? It burns out all the time after turning the ignition switch. Thank you for your help!
  • #2 16740280
    ossi_cw
    Welcome back!!
    Will colleagues mate this FUSE?
    Greetings!
  • #3 16740408
    fuelinyourblood
    Help: 226
    Rate: 1391
    Instead of a fuse, put in the wires under the car. As the bulb shines brightly you have a short circuit, how dark it is a short circuit. With such a circuit, you move a bundle or unfasten the receivers on this circuit. You will find a short circuit.
    Have fun.
  • #4 16742042
    citromaniak
    Help: 53
    Rate: 394
    Passenger's divider, so look for a short on the lamp from the storage compartment, make a clipboard if you can and look maybe something somewhere zware.
  • #5 16745825
    genek1000
    Help: 289
    Rate: 1057
    I apologize for the stupid question: how do you know that it burns :?: Something must have stopped working :?:
    The fuse is hanging:
    - control element
    switching on / off the regulator - speed limiter
    relay 1 and 2 additional heating on the plate
    relays in the cabin
    - diagnostic socket
    - module
    complex proximity radar
    - tachograph
    Do not you operate a CB radio or lighting in "Kurnik" :D
