Renault / Master II / 2007 - no position front / rear left side and backlight cl
dzidekkw 13701 6
  • #1 16716647
    dzidekkw
    Rate: 24
    Hello, I bought Master 2 from 2007 and it does not work in the position lights on the right front and rear. In addition, no dashboard illumination (other lights are on) and no license plate illumination. I checked the fuses in the cabin and the cubes under the body. It seems all good, gentlemen, what could it be ??
  • #2 16716661
    milejow
    Help: 1559
    Rate: 5129
    dzidekkw wrote:
    Everything seems good
    It's a bit too little, you have to be sure they are good. Right position, registration and breath are hanging on the same fuse - what's the conclusion?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #3 16716669
    sulof1601
    Help: 94
    Rate: 280
    Hello. Certainly the fuse A seems to be irresistible to me. Check the fuse in the cabin number 15 carefully for blown and whether there is voltage on it.
  • #4 16716716
    jarek225
    Help: 64
    Rate: 219
    Here is the description of all fuses.
    Good luck
    • RENAULT_Master_II_2_5_dCi_120.rar (533.25 KB) You must be logged in to download this attachment.
  • #5 16716761
    dzidekkw
    Rate: 24
    Gentlemen, I went to check the fuse again at the moment, in the dark of 21:00, it turned out that the fuse from the right positions is blown! And during the day I checked it with a meter and it was OK. Now I put a new one, I turn the control handle, the lights come on for a second, along with the lighting of the clocks and the cut! Fuse blown, lights go out. Tomorrow, during the day, I will check where the short circuit is being made ... I suspect that the beam may be disturbed over the silencer, where are these cover sheets .. I have them damaged .. Do you suggest me where to check? Maybe you know sensitive points?
    Thank you very much for your support and help :)
  • #6 16717435
    sulof1601
    Help: 94
    Rate: 280
    It is difficult to say if there are sensitive places rather search just where the beams pass and there are mechanical damages as well as in lamp fittings. Fruitful searches.
  • #7 16718988
    dzidekkw
    Rate: 24
    Found, short circuit on license plate lighting, corrosion, replaced, now right hand position and clock lighting is on :) Thank you for your help
✨ The discussion revolves around a 2007 Renault Master II experiencing issues with the position lights on the right front and rear, as well as dashboard and license plate illumination. The user initially checked the fuses in the cabin and under the body, finding them intact. Subsequent responses suggested checking specific fuses, particularly fuse number 15 in the cabin. After further investigation, the user discovered a blown fuse for the right position lights, which was intermittently functional. The user suspected a short circuit due to damaged wiring near the silencer. Ultimately, the issue was traced to corrosion in the license plate lighting, which was replaced, restoring functionality to the right position lights and dashboard illumination.
