Whirlpool AKZ 237 Oven Button Lock Issue - Key Symbol, Unlocking Buttons, Limited Functions
Przzz 50733 6
  • #1 16727047
    Przzz
    After switching the oven off and on, a key symbol appeared on the display suggesting that the buttons should be locked. Nothing works except the clock. Each time you turn the knob, a key symbol appears.
    The problem is that in the AKZ 237 oven manual there is nothing about button locking. In other Whirlpool ovens it is described how to unlock such a lock by a combination of different buttons. However, in AKZ 237 there is only one button and I have no idea how to use it to unlock this lock. Do you have an idea how to do it?
  • #2 16727318
  • #3 16727346
    Przzz
    skryn wrote:
    Where?
    The key symbol appears on the display.
  • #4 16728381
  • #5 16728461
    Przzz
    The 12NC code for this Whirlpool AKZ 237 / IX oven is: 858523701002
    Thanks for the help. I got a tip to disconnect from the power for an hour to restore factory settings, but unfortunately nothing helped. Next the oven is blocked and the key on the display.
  • #6 16728523
  • #7 16783301
    Przzz
    Unfortunately, this oven could not be repaired. I had a few phone calls with various service technicians, one was there twice and the conclusion is one. It is not possible to restore the factory settings, the module is not programmable. The only repair option is to replace the main oven module, but I did not decide on this option, because it would cost me 600 PLN, so almost the price of a new oven.
    Thanks for the help, topic for me to close.
The Whirlpool AKZ 237 oven is experiencing a button lock issue indicated by a key symbol on the display, rendering all functions inoperable except for the clock. The user noted that the manual does not provide guidance on unlocking the buttons, unlike other Whirlpool models. Responses suggest entering the 12NC code (858523701002) for further assistance, but it was determined that the software version requires service intervention to restore factory settings. Attempts to reset the oven by disconnecting it from power were unsuccessful. Ultimately, the only solution proposed was to replace the main oven module, which was deemed too costly compared to purchasing a new oven.
