Amica oven EBI81074 - The display is blocked. the key popped out
tonygold 155682 2
  • #1 15054243
    tonygold
    Rate: 122
    The display showed the message "press simultaneously for 3 seconds."
    I press the arrow and "ok" at the same time, but nothing happens, the display is dim a bit, but the key that can be seen on the upper part of the display to the right is still there. I used to have the same defect and found a post on Elektroda.pl, but today I can't find it.
    Thank you for your help
  • #2 15055025
  • #3 15055079
    tonygold
    Rate: 122
    Thank you so much, it worked
    best regards
