[Solved] AKP706 whirlpool oven - remove the door to stick the internal glass
pardwa 16452 2
  • #1 17195497
    pardwa
    Rate: 9
    I have an old electric cooker AKP 706 whirlpool in which the inner glass of the oven has come off. Need to stick, but how to get?
    I want to remove the door, but how? There are no covers or hinge clamps. The hinges cannot be removed. I started to unscrew more screws from the housing to somehow get to the hinges, but the housing with the gasket feels like a push. Need to disassemble the housing?
    How do I remove this door?
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2657
    Most ovens have a removable door and the principle is similar (with some exceptions).
    Read here: Link
  • #3 17196016
    pardwa
    Rate: 9
    Thank you very much, the door is removed, washed and the glass is glued with black silicone. Now I will wait for sticking and I will have to put the door in. I hope it will work
