Kyocera FS-C5350DN Printer: Tackling 'Call Service 7404' Post-Y Toner Replacement & Cleaning
wrsls-k2 6381 6
  • #1 16727676
    wrsls-k2
    I have a Kyocera FS-C5350DN printer, which showed a message about the need to replace the Y toner. I replaced the toner and even put 3 different ones and it was still the same. Then I took the printer apart and cleaned it properly, the problem was for sure because the powder was killed in all possible places. After cleaning, the toner traveled freely from the container to the developer, but the message to replace the toner remained. The last thing that came to my mind is to clean the developer. There was a powder inside the developer, but it was brown rather than yellow. The developer was flooded with a new one.
    The printer now shows Call Service 7404.
    I had the same problem a year ago and the printer went to the service - they fixed it, but it seems that the developers did not replace it (because the powder would be in better condition) and the blue cap is broken (so I conclude that they did not even look there). I think they did a developer reset in service mode and the printer came to life.
    People who revived their developer and solved a similar problem, please help and give a specific hint. Thank you.
  • #2 16727742
    jerry74
    Help: 21
    Rate: 58
    I understood correctly that you spilled everything out of the developer module. everything that was there and you covered with only powder (toner)?
  • #3 16730501
    krzys_ka
    Help: 111
    Rate: 86
    There is no such thing as a developer reset. Not on these models. It remains to buy a new calling unit Y or look for used ones. In its current state, the printer is a useless piece of furniture. I recommend reading the small colorful kyocer topics here on the forum.
  • #4 16736947
    wrsls-k2
    This is how I poured out the old toner and covered the developer with a new one.
  • #5 16737362
    pecet7
    Help: 24
    Rate: 80
    Where did you get the developer for FSC5350? Was it a developer dedicated to this model? To my knowledge, there is no powder for this model anywhere.
    The only solution is to replace the entire developer module with a new or functional one.
    jerry74
    Help: 21
    Rate: 58
    I'm afraid that my colleague got rid of the developer from the developer module and sprinkled only toner (powder).
    wrsls-k2, the developer itself is brown, like iron filings, it combines with the toner in the developer module, wrong developer and toner ratios result in error 740x.
  • Brown developer restored to fix 7404 error
    #7 16738866
    wrsls-k2
    Thanks, buddy for the hint, because I didn't even know, now I'm checking and there are actually filings.
    Added after 1 [hours] 46 [minutes]:
    jerry74 thanks for the hint.
    I crushed the old toner (the brown one) and covered it with the developer.
    Problem solved. The printer works.
The discussion revolves around the Kyocera FS-C5350DN printer displaying a 'Call Service 7404' error after a yellow toner replacement. The user replaced the toner multiple times and cleaned the printer, but the error persisted. Responses indicate that the developer module may have been improperly handled, with suggestions that the user might have used incorrect developer powder, leading to the error. It was clarified that a developer reset is not possible for this model, and the only solution is to replace the entire developer module. Ultimately, the user resolved the issue by crushing the old brown toner and mixing it with the new developer, restoring printer functionality.
