Konica Minolta C250 – C-FB52 on copy, demo print works: what to check?
serwek 5064 4
  • #1 11957407
    serwek
    Help: 65
    Rate: 261
    Welcome
    The Konica Minolta C250 copier displays the error code: C-FB52
    Turns on, heats up. You can print the demo test, it comes out very nicely.
    There is a problem when trying to copy.
    After pressing START, this code C FB52 crashes.
    Can you give me what is going on?
    ": serwek" ;)
  • #2 11957758
    Bitels85
    Help: 72
    Rate: 166
    According to the service motherboard (CFB52 DMA_A error interruption), nothing more I can not say, turn on the device with the button / counter pressed and press the button on the panel "troubleshoot reset button" which appears immediately after the minolta logo and restart the copier too probably nothing gives ...
  • #3 11957789
    serwek
    Help: 65
    Rate: 261
    I know that the website is written:
    CFB52 DMA_A error interruption • MFP Control Board C
    But something I do not want to believe to do so by itself "down" ... :(
    Tomorrow I will check the wires, no more power today
    "serwek" ;)
  • #4 11958260
    copyman
    Photocopiers specialist
    Help: 1105
    Rate: 833
    Maybe to the complete set, reinstall its firmware.
    C.
  • #5 12211508
    serwek
    Help: 65
    Rate: 261
    Welcome
    The machine finally entered our warehouse.
    In free time I leaned over her for a moment.
    Unfortunately, one thing I noticed is:
    After entering the service, in the section: HDD / MEMORY BUS / SCANNER MEMORY -> TEST / start, after pressing "losses" immediately pops up "CFB53", not "CFB52" - interesting ...?
    The test (MEMORY PRT) passes - OK
    I still do not know where it's allocated scanner memory ... < br />
    Do you have any ideas?
    Regards :)
    "Serwek"
    P.S.
    I shed a CD50 from C250 somewhere ...
    Can you give me info on how to do NOV-RAM?
    Do you have a different firmware to c250? I would try it to upload others
    Do you have files for her?
    Hot request to send - on priva ;)
    It's a shame to scrap the razor ...; (
