Kyocera FS-2020D: Load MP Tray PLAIN A4 Message - Opening Paper Pocket, Printer Prints
LaBelias 28023 4
  • #1 12798477
    LaBelias
    Kyocera fs-2020D
    During printing, a message is displayed on the printer: Load MP Tray PLAIN / A4
    It is interesting that if I move something (eg open a pocket for paper), the printer sometimes prints something.
    forteca
    KYOCERA specialist
    Help: 144
    Rate: 82
    the printer needs to put the paper in the manual feed:
    1. or you have an unfinished task with a printout from the manual tray
    2. or you have a multi-purpose tray set up on the computer as the main tray
    3. or you have a faulty feeder sensor
  • #3 12799882
    LaBelias
    When this error pops up, you can press the tab down on the printer and there is the option Use alternative Cassette and then prints without a problem. Only this time you have to choose this option. I would like to add that the printer worked until recently without any problems and suddenly the lichen began to appear.
  • #4 12800183
    forteca
    KYOCERA specialist
    Help: 144
    Rate: 82
    Apparently, you have set the so-called fersta, that is, the printer will always pick up paper from the manual tray or you have the source of paper set in the controller as a multi-purpose tray. You have to put the drawer in the controller and change it on the printer.
  • #5 21238639
    yarecky81
    On the ECOSYS P2040dn, the same printing problem has to be solved like this:
    In the "print preferences" window under the "Basic" tab, select:
    Source: Automatic
    Media type: Automatic Media selection.
