SKODA FABIA II 1.6 TDI Gearbox Oil Change - Checking and Replacing Quantity, Noise Solution
jump$ 7137 1
  • #1 16729028
    jump$
    Help: 7
    Rate: 115
    Recently, I have noticed that the gearbox works louder when shifting gears and on a cold engine I hear a strange strange noise from the gearbox side. After pressing the clutch all the way, this sound disappears.
    I decided to replace the oil with a new one because it was never changed.
    How much oil should I pour into the chest, where can I find this information?
  • #2 16729229
    Pedros050
    Help: 2471
    Rate: 3918
    Hello. First of all, it is not the oil that makes the gearbox loud, only the thrust bearing on the clutch and the hopper is 2 to 2.3 liters, you have a filler plug on the side and pour until it starts to pour out.
