Fabia 1.2 HTP 6v 2004 - taking 1 liter of oil per thousand km
magnus27 21648 16
How can I tell whether my Fabia’s oil consumption is caused by valve seals, piston rings, or something else?
Check for external oil leaks, oil in the coolant, blue exhaust smoke after revving, and whether the crankcase ventilation (“emphysema”) is carrying too much oil [#16523486][#16523961][#16557655] A compression test is a useful next step, but the thread says the cause can also be worn valve stem seals, worn oil-control rings, a damaged head or head gasket, or leaks elsewhere [#16557655] One reply also says this engine has natural wear and that 1 liter per 1000 km is still not considered high consumption by the manufacturer [#16524112][#16525665] If you want a definite diagnosis, the only sure way mentioned is to open the engine and verify it, because replacing rings alone may only help briefly [#16523715][#16524112]
  • #1 16523455
    magnus27
    Rate: 310
    Hello, my fabia began to take about 1 liter of oil per thousand km, how to check whether it is sealants or rings?
  • #2 16523486
    Foxtrott
    Help: 253
    Rate: 944
    What color are the exhaust gases after "gasification" on the engine?
    Are there traces of oil in the coolant?
    Are there any traces of oil on the engine body? (Wet spots)
    What does pneumothorax look like?
  • #3 16523715
    Alfred_92
    Help: 148
    Rate: 706
    Disassemble the engine and verify.
    But the glass ball suggests that they can be rings.
    He began to take more and more gradually, or so suddenly right away?
  • #4 16523896
    magnus27
    Rate: 310
    He started taking it gradually, tomorrow I will measure the compression. And how to check pneumothorax? Maybe the rings got stuck in some cars, apparently helped flooding the cylinders with kerosene.
  • #5 16523961
    Foxtrott
    Help: 253
    Rate: 944
    Check the emphysema = does it spit too much oil
  • #6 16523962
    robokop
    Help: 1763
    Rate: 6371
    Nothing baked, natural wear, not the happiest engine. It remains to get used and top up regularly.
  • #7 16523978
    magnus27
    Rate: 310
    Yes, the engine is not the happiest, the head was made twice with it due to burnout of the exhaust valves for the first time at 70 thousand, the second time at 120 thousand. Any of you exchanged rings on this engine?
  • #8 16524112
    robokop
    Help: 1763
    Rate: 6371
    Replacing the rings alone won't do anything - at most for a while, and then it will get worse. Flood it with 15W40 and ride until it begins to leave the blue cloud behind. A liter per 1000km is not yet high consumption.
  • #9 16524124
    Foxtrott
    Help: 253
    Rate: 944
    robokop wrote:
    cut ... A liter for 1000km is not a big consumption yet.
    sorki for off top but for me it's a "failure"
  • #10 16524253
    Alfred_92
    Help: 148
    Rate: 706
    Then look at the instructions of any VAG and you will see what is the specified standard, regardless of whether the Passat B7 or Golf II had a defined standard of 1l per 1000km
  • #11 16524435
    sk700
    Help: 173
    Rate: 420
    This is a dupochron to reduce the number of warranty repairs, in fact, efficient, do not pull that much :)
    This whole motor is a failure, neither dynamic, economical nor durable. But every model should have such an engine on offer, this allows you to keep the prices of body parts for copies with normal engines :)
  • #12 16525232
    Sofeicz
    Help: 12
    Rate: 123
    Not completely. Some companies do so by nature, e.g. BMW.
    My Saint The 1.8 16V lantra also took about a liter in 1000. Such a beauty.
    And for a change, the current old Twingo - ZERO consumption from oil change to oil change.
  • #13 16525287
    vodiczka
    Help: 1185
    Rate: 4311
    Fabia 1.2 HTP 12V too :)
    Are you kidding, I understand one or two refills from exchange to exchange but 10l / 10,000km? I think he was resuscitated.
    What is your mileage
  • #14 16525665
    robokop
    Help: 1763
    Rate: 6371
    Gentlemen, stop raving about what you don't know, because it will happen that your cars will produce oil instead of using it. Each internal combustion engine "takes" oil - it results directly from the principle of its operation, mechanical construction and properties of the oil itself. Only that some engines consume less, others more. Only when the consumption is exceeded, specified by the manufacturer, one can see the pathology. I do not intend to explain again to each individual what it depends on. I close the thread, as the answer to the theme has already been given.
  • #15 16557579
    Pawel wawa
    Help: 1262
    Rate: 4432
    A request to unlock the topic: "I measured compression on cylinders and would like to know if it is the fault of the rings?" At the author's request, I opened the topic.
  • Compression readings suggest rings are likely okay
    #16 16557609
    magnus27
    Rate: 310
    here is the compression measurement results:
    1 cyl - 13.8 bar
    2 cyl - 14 bar
    3 cyl - 13.2 bar
    Can the rings be damaged with this result?
    Can the blame for taking oil be affected by pneumonia? Can it be stripped and cleaned / https://www.google.pl/url?sa=i&rct=j&q=&esrc=...ved=0ahUKEwiJ8KqTqdfUAhWEYpoKHTyuC3wQlAhFtt2w .com 2Fskoda%-fabia-1-2-6v-famous-emphysema-engine-703907.html & psig = AFQjCNHcc7micAjx4NLT-fN6q BsiGoBIA &-paragraph = 1498422553187742 & cad = RJT
  • #17 16557655
    tc
    Help: 30
    Rate: 99
    there can be many reasons. sealants on valves, worn oil rings, damaged head or gasket under it, and possible leaks. In golf IV, probably with a 1.4 engine it happened that the culprit was the sticking emphysema which the engine dumped oil.
The discussion revolves around a 2004 Skoda Fabia 1.2 HTP experiencing significant oil consumption, approximately 1 liter per 1000 km. Users suggest various diagnostic approaches to determine the cause, including checking exhaust gas color, coolant for oil traces, and inspecting for leaks on the engine body. Compression tests are recommended, with results indicating acceptable levels, leading to speculation about potential issues with valve sealants, oil rings, or the head gasket. Some participants note that oil consumption can be a characteristic of certain engines, while others express concerns about the engine's overall reliability and performance. The consensus suggests that while 1 liter per 1000 km is not excessively high, it may indicate underlying wear or issues that could worsen over time.
