Samsung UE55MU9009TXZG: How to Change Region from DE to PL in Tizen System (MU9000 Model)
awyciu 7944 15
How can I change the Samsung UE55MU9009TXZG region from DE to PL in Tizen?
You can change it in the service menu, not from the normal Tizen menus, and you need a service remote to do it [#17159792] Enter SERVICE MENU, then OPTION, then LOCAL SET, and change the region to EU or EU_POLAND [#17159792] One user reported that after switching it to Poland and then EU, Polish channel search and Smart services worked correctly [#16771704] The only caution given was not to change other settings unnecessarily [#17159792]
  • #1 16743807
    awyciu
    Hello, I have a question if someone is oriented or in this model MU9000 there is the option of regional change from DE to PL, I ask because I am looking for and about regional change in the Tizen system nothing and nothing found. Please help.
  • #2 16744220
  • #3 16744383
    awyciu
    Very helpful answer
  • #4 16747052
    JARPAW7500
    Rate: 30
    Changes can be made in the service mode because it is probably set to EU GERMANY, you can change to EU
  • #5 16747357
  • #6 16747703
    JARPAW7500
    Rate: 30
    The boards are released to various markets in the service options it is possible to change the region code (you can always check it). If you know better then you would help a colleague who asked a question and not write about markets.
    In your life write what countries you have to choose in the tuning option. I agree that these tvs with the TXZG model tip were not produced on the Polish market but as I wrote they should be able to change the region in the service options.
  • #7 16770452
    Sebaso22
    As my entry was deleted by a moderator - I will try to explain how I want to the notifier ...
    Also, I have a similar problem with a TV purchased in Germany, only in my case it is a Samsung UE55MU lower class - 6000 series. I wanted to check the region which is set in the service menu but unfortunately I can not enter it, because the remote control included in the set is a remote control " smart "... I even borrowed a remote control from an older TV that works, but the key combination from the net to enter the service menu also doesn't work .... as far as I know the MU series is the 2017 series so it is new and both PL which ANG The forums do not reveal how to enter the menu ....
    So I can't determine at the moment whether the service menu has something like a region change ...
  • #8 16771086
    DiZMar
    Help: 2891
    Rate: 6648
    What is wrong with you?
  • #9 16771704
    awyciu
    Hello again, a colleague from the JARPAW7500 forum contacted me, we talked on the phone, gave me tips on how to buy a service remote control and did so, as it came about the order was kindly again step by step by phone explain everything and how and when I have press on this remote control and thanks to it the TV entered the service mode, not like from the level of a normal remote control because I also have a second samsung tv and a second ordinary remote control and here we are talking about the real service mode in which I selected the region from the list for Poland and after the EU, is when searching for NC +, Polsat and all smart services are also Polish.
    So that gentlemen professionals what you smiled only with a colleague JARPAW7500 I will tell you that he should fry with you, he has a guest knowledge and he was not wrong, it was worth to listen to him and recommend him
  • #10 16773352
    Sebaso22
    awyciu .....
    Maybe you will share information with a friend .... I will also be happy to change the region ....
  • #11 16892500
    Gladarek
    I have the same problem and I have a service remote control you can ask for tips like this. do
  • #12 16892708
    Sebaso22
    You need to purchase a service remote or try to call Samsung on the support lines.
    I changed the remote control, but the sister I bought the phone rang and said that they had to check, because maybe there is a possibility of remote change by a service employee ...
    Here is the pilot's manual ...
    http://www.afstandsbedieningwinkel.nl/manual/anleitung-service-1.pdf
  • #13 17159472
    globan
    will someone explain step by step how to change the region? thanks and best regards
  • #14 17159483
    Sebaso22
    The question is whether you have a service remote ...
  • #15 17159538
    globan
    I didn't expect such a quick response. Pilot on the way. I think it will be by the end of the week.
    UE557000 TV English version
  • #16 17159792
    JARPAW7500
    Rate: 30
    Hello. Service remote control in hand SERVICE MENU-OPTION-LOCAL SET and change to EU or EU_POLAND and it works only it is better not to change anything.
The discussion revolves around changing the region setting of the Samsung UE55MU9009TXZG (MU9000 model) from Germany (DE) to Poland (PL) within the Tizen operating system. Users express challenges in accessing the service menu necessary for this change, primarily due to the limitations of the standard remote control. It is suggested that a service remote control is required to enter the service mode, where the region can be adjusted. Some users successfully changed the region by following guidance from others who had experience with the process. The importance of using the correct remote and the potential risks of changing settings are emphasized.
TL;DR: You can change Samsung MU9000/MU6000 region from DE to PL via Service Menu; 1 confirmed success. “selected the region … for Poland.” Use a service remote. [Elektroda, awyciu, post #16771704]
Why it matters: This fixes Polish channels and Smart services without hardware mods. Ideal for buyers of German-market sets needing Polish features.
How do I change a Samsung UE55MU9009TXZG region from DE to PL?
Use a Samsung service remote to enter Service Menu. Navigate OPTION → LOCAL SET and choose EU or EU_POLAND, then restart. One user confirmed success with Polish channels and Smart services after this change. “selected the region … for Poland.” [Elektroda, awyciu, post #16771704]
What exact Service Menu path was reported for MU series?
SERVICE MENU → OPTION → LOCAL SET → select EU or EU_POLAND. The contributor added a caution: "better not to change anything" besides Local Set. Apply only this change, then power-cycle the TV. [Elektroda, JARPAW7500, post #17159792]
Do I need a special remote to access the Service Menu?
Yes. The bundled Smart remote typically cannot invoke the Service Menu on MU series. Users succeeded only after obtaining a dedicated Samsung service remote. Regular older remotes and common key combos did not work. [Elektroda, Sebaso22, post #16770452]
Is there any user-confirmed success after switching to EU_POLAND?
Yes. One owner reported entering true Service Mode with a service remote, selecting Poland/EU, and then seeing NC+, Polsat, and Polish Smart services available after setup. [Elektroda, awyciu, post #16771704]
Where can I find a service-remote manual or reference?
A forum participant shared a service-remote manual link when discussing remote-based entry to the menu. Use it to understand key mappings before attempting access. [Elektroda, Sebaso22, post #16892708]
What if my TV’s model suffix is TXZG (German market)?
A contributor noted TXZG units were not produced for PL retail, yet Local Set still allowed EU/EU_POLAND selection in Service Menu. Proceed only with Local Set changes, then reboot. [Elektroda, JARPAW7500, post #16747703]
Will changing the region impact channel scanning and apps?
Yes. After selecting Poland/EU, a user reported Polish platforms (NC+, Polsat) and Smart services appearing in Polish during setup and scanning. [Elektroda, awyciu, post #16771704]
Can Samsung Support change the region remotely?
One poster suggested contacting Samsung support; they were told a remote change might be possible after verification. This is not guaranteed and depends on support policies. [Elektroda, Sebaso22, post #16892708]
What is Tizen, and why does it matter here?
Tizen is Samsung’s TV operating system. Region in Tizen controls available broadcast standards, app store availability, and initial setup language defaults on MU series. [Elektroda, Sebaso22, post #16770452]
What is the Service Menu and Local Set on Samsung TVs?
The Service Menu is a hidden configuration interface. Local Set defines market presets like EU or EU_POLAND, which tune regional features and apps. Change only Local Set as advised by the experienced poster. [Elektroda, JARPAW7500, post #17159792]
Quick how-to: change MU9000 region to Poland (3 steps)
  1. Use a Samsung service remote to enter Service Menu.
  2. Go to OPTION → LOCAL SET and select EU or EU_POLAND.
  3. Power off, then on; run setup and scan to load Polish services. [Elektroda, JARPAW7500, post #17159792]
What can go wrong or not work as expected?
Edge case: Smart remotes and older standard remotes may not open Service Menu on MU models. Also, the expert warned not to change other service items, implying risk of misconfiguration. [Elektroda, Sebaso22, post #16770452]
Is a region change possible on other MU-series sizes (e.g., UE55MU6000)?
A MU6000 owner reported the same access limitation with a Smart remote, then pursued a service remote to attempt the same Local Set change. The approach mirrors MU9000. [Elektroda, Sebaso22, post #16770452]
Does a TV prepared for a given market allow region switching at all?
One reply claimed TVs are prepared for a given market. However, other posts show Local Set changes enabled EU/EU_POLAND on German units, with success reported. [Elektroda, 1098678, post #16744220]
