Oil Electric Heater Heating Time: 15, 30, 60 Minutes Comparison for Radiator vs Convector
danielo0 8823 4
  • #1 16754401
    danielo0
    Hi, I'm going to buy an oil radiator, but they supposedly heat up longer than convector heaters, and how much do they heat up 15.30 minutes an hour because I can't find any information anywhere?
  • #2 16754461
    Barton-wlkp
    Help: 26
    Rate: 90
    Such a generally asked question cannot be answered.
    Heater power, heat capacity (weight x specific heat). Too many unknowns.
    The difficulties in the distribution of heat can be ignored.
  • #4 16754476
    Barton-wlkp
    Help: 26
    Rate: 90
    But it can be accurately calculated.
    If you want to check it carefully, go to the store and connect. You have the right to it.
    On the other hand, the longer it heats up, the longer it will give up energy after being turned off.
    Take into account that both of these heaters heat using a different phenomenon and individual feelings may differ significantly despite the identical power of the devices.
  • #5 16754902
    retrofood
    Help: 1140
    Rate: 4788
    danielo0 wrote:
    Hi, I'm going to buy an oil radiator, but they supposedly warm up longer than convector heaters.
    It is obvious. The heater does not heat the air, but the oil. How long does it warm up? I guess 15-20 minutes. I have such a flat 800 W and after about 20 minutes it is already hot.
